Jaguar NAV Kit Instructions & Illustrations
Old 08-30-2011, 09:39 AM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default Jaguar NAV Kit Instructions & Illustrations
Hi
I found this 2001 XJ8 Navigation Install Kit instructions on the topix.jaguar website:
TOPIx - TOPIx
In Select a document section - I choose item 1 LNG3650FIT-410 - Navigation System (North America Only)
The next screen brought up the fitting instructions (29 pages) viewed as a PDF file in the internet browser.
You can use the printer icon on the top blank menu bar to view it in your own Acrobat software.
This document shows all the Nav components that come in the install kit and all the Instructions and Illustrations that cover all the removal and reinstall steps.
The JTIS does not seem to give enough instructions and illustrations on the audio system components so
I am including this list of the steps in the hope that forum members can use this information to:
Remove stuff like the radio, or add/modify something in the stock harness, or remove a seat, the carpet, and most of the IC (In Car entertainment system components).
I used the print icon to get the PDF view of the document, then I saved the PDF file and uploaded to my mediafire account - here is the weblink to the PDF file:
2001 XJ8 Navigation Install Kit.pdf
Here is the list of steps:
Removal of the covers around the gearstick
Removal of the radio
Removel of Climate Control Panel
Center Console removal (Floor Console)
Center Console Glovebox (Floor Console Storage Compartment)
Rear Center Console A/C vent control
Removal of Rear Seat Cushion & Rear Seat Backrest
Removal of Parcel Shelf above Rear Seat Back
Driver Seat Removal
Lifting Carpet to get access to the Harness on side of tunnel
Installing New Harness under Carpet on side of tunnel
Removing the Assist Handle over Rear Door
Detaching the door aperture weatherstrip
Removing the rear courtesy/reading light
Detaching the C-pillar trim panel over Rear Door
Removing Rear Harness to Heated Rear Windscreen
Removing Luggage Compartment Floor, Side, and Back Panels
Detaching Harnesses to Antenna Motor and Autochanger/amplifier assembly
Adding new Nav Harness
Adding Navigation Unit to Autochanger/amplifier assembly
Then step by step reinstalling instructions and illustrations
Jim Lombardi
Cadillac (08-31-2011)
Old 08-30-2011, 03:03 PM
Stu 1986's Avatar
If anyone is interested I have a Jaguar Nav unit and head unit for sale. It is from the UK so you will need the relevant disc. This was removed from a 2001 XJ8 and it will not fit in models 98/99 I'm not sure about the 2000 MY though.
PM me if interested
Old 08-30-2011, 04:43 PM
Boomer from Boston's Avatar
Does Jaguar even sell these anymore? If so, for how much?
Old 08-30-2011, 06:26 PM
luc's Avatar
luc
luc is offline
I have installed the factory NAV in my 01 XJR and i can tell you that this document is missing the MOST important information:
The system will not work until a special CD ( that I have) is used to wake-up/program it.
Problem is, most dealers have no clue about this step nor which CD to use
Originally Posted by jimlombardi
Hi
TOPIx - TOPIx
Driver Seat Removal
Jim Lombardi
jimlombardi (08-30-2011)
Old 08-31-2011, 03:25 AM
Cadillac's Avatar
Thanks jim, useful post us usual , FAQ'ed
paulyling
Mark V - X 420G
08-15-2023 09:33 PM
SD96XJ6L
01-12-2022 04:30 AM
Stoney85
Australia - Queensland
06-07-2021 11:49 PM
Tbelo19
09-06-2015 10:25 PM
plums
General Tech Help
09-01-2015 06:34 AM
Quick Reply: Jaguar NAV Kit Instructions & Illustrations
