Lincoln LS 3.9 and Jag XJ8 4.0: Same Valve Cover Gasket?
Old 04-19-2011, 02:54 PM
SirJag's Avatar
Default Lincoln LS 3.9 and Jag XJ8 4.0: Same Valve Cover Gasket?
Anyone happen to know if these engines would share the same valve cover gaskets? Just spoke with a tech at a gasket mfgr and one of their products is not spec'd for a 2001 VDP, but for a Lincoln LS with a 3.9 DOHC engine, but one Ebay seller says it fits the VDP.
Anyone have any experience with this?
Thanks,
SirJag
Old 04-19-2011, 04:40 PM
SirJag's Avatar
UPDATE: I went ahead and ordered this after some research. I'll let everyone know what I learn.
SirJag
Old 04-19-2011, 08:51 PM
Sinister 1's Avatar
Yes they are the same. I used them on my engine when I did the Tensioners.
BTW the tensioners are the same also. Note however that the chains are not.
SirJag (04-21-2011)
Old 04-19-2011, 10:24 PM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
What's the difference in the chains? Are they better, worse?
Old 04-20-2011, 12:25 AM
Dan R's Avatar
I have had good luck with Fel-Pro gaskets. Cataloged for Lincolns but they fit the Jag.
SirJag (04-21-2011)
Old 04-20-2011, 12:38 AM
dsetter's Avatar
Agreed, Fel-Pro fitted perfectly, all parts for cover seals, plug seals, screw seals.
Seems you need to assemble the bolt seals outer with the cover seal to hold it all together.
SirJag (04-21-2011)
Old 04-20-2011, 06:26 PM
bluerdg's Avatar
Check out Christopher's Foreign Auto Parts online. Best price by far I could find for a full timing chain kit for an '01 XJ8 - I got everything chains, tensioners, new bolts, valve, plug, and timing cover gaskets - valve cover bolt seals, and both styles of VVT seals in one kit, he even threw in a crank shaft pulley bolt, and I picked up the upgrade waterpump and thermostat all shipped together. He's got a variety of kits put together as well as individual components. Based on the cost I imagine there are a few of the cross referenced Lincoln parts in his kit ( I did get a bunch of stuff with Jag labels on the bags though), but everything I got fit perfectly and each part was clearly labeled. I'm getting ready to see if he's got parts to do the timing on my MX5.
SirJag (04-21-2011)
Old 04-20-2011, 09:39 PM
Sinister 1's Avatar
The Ford/Lincoln version is completely different and would not fit the teeth on the VVT or any of the JAG's gears. I think It had something to do with early Ford/Lincolns not having VVT's. I did not bother digging and reused my existing chains.
I did however use the Ford/Lincoln Primary & Secondary Tensioners, Guides, Front Cover Gasket, Crank Seal, Oil Pan Gasket, and Valve Cover Gaskets.
SirJag (04-21-2011)
Old 02-05-2016, 11:08 AM
18 & XJR's Avatar
Hey, bringing up an old thread, but would this valve cover gasket also work on a 1998 Jaguar XJR? It's a 4.0 as well but everything I'm reading says 2000-2003. Here's what i'm looking at Valve Cover Gasket Vs50397 - Victor Reinz (VS50397)
Old 02-05-2016, 11:31 AM
Samilcar's Avatar
If your engine is original, that's the wrong gasket. The 1998 gasket is thicker, and the spark plug well gaskets are connected, not separate (http://www.ebay.com/itm/371240133843?rmvSB=true). If you have a later replacement engine (like in my vehicle), then that gasket will work. Only way to know for sure is to take off a valve cover and have a look.
The following 2 users liked this post by Samilcar:
18 & XJR (02-05-2016), motorcarman (02-05-2016)
Old 02-06-2016, 10:15 AM
XJDanny's Avatar
Are the Lincoln gaskets cheaper? I need to get a pair because I've developed an oil leak on my 02 XJR.
Old 02-06-2016, 05:49 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
The FelPro valve cover gaskets for the '00-'02 LS fit the AJ27 engine ('99-'02 XJ/K8, '00-'02 XJ/KR), but not the earlier AJ26, and were under $40 at Advance AP's when I bought mine. The Jaguar branded gaskets can be twice that.
XJDanny (02-07-2016)
Old 02-07-2016, 02:57 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Order from SNG. Got mine there. I think half the Jaguar price...
xjrjag
10-27-2021 11:48 PM
Bcrary3
08-31-2015 11:29 AM
SkinnyLard
08-30-2015 07:26 PM
SkinnyLard
08-29-2015 04:24 PM
peterg19
08-28-2015 08:42 AM
Quick Reply: Lincoln LS 3.9 and Jag XJ8 4.0: Same Valve Cover Gasket?
