Lower Ball joints and Outer Rear Hub bearing replacement
So looks like my next project will be fixing all of this. I've been able to find the Outer Hub bearings in my JEPC, but I can't seem to find the lower ball joints.
Also, what am I looking at time wise? I was told roughly 2 hours per joint and no idea on the bearings.
Also, is there a guide anywhere for this? I tried searching and wasn't able to find a step by step picture guide.A video would also be great.
Hi
The lower ball joint is usually sold as part of the front lower wishbone RH rear (JLM21302) and front lower wishbone LH rear (JLM21303). They are $256.75 each at Gaudin Jaguar.
Do not worry because Jagbits sell the lower ball joint assembly as part number MNC1350AA-OE for $79.78 each. Jagbits also says this: "This item is NOT available from any Jaguar dealer, they will only sell the entire control arm which will include this ball joint."
Here is the website link:
Jaguar - Lower Ball Joint
I used the part number to find it at another vendor on the internet.
SNG Barratt -USA (located in Vermont) has it for $23.13 aftermarket and for $39.96 OEM.
SNG Barratt - USA | Parts | Lower Ball Joint
Front lower wishbone std labor hrs is 1.9 hrs each side per ALLDATA.
The rear hub outer wheel bearing (CAC6333) at Gaudin Jaguar is $25.84 plus shipping.
Also try Nalley Jaguar - another forum sponsor - might have better price and free shipping.
All Data has the rear wheel bearing standard labor at 2.3 hrs for one side.
Jim Lombardi
Jim Lombardi
soprecious (12-15-2012)
Hello again
I just extracted the Front Lower Wishbone Rear Removal & Install instructions from my JTIS21 CD that is stored on my PC:
2001 XJ Front Lower Wishbone rear R&I.pdf
Also you might have to find a local machine shop to remove the balljoints from the Lower wishbone rear (need to press to do it), also have them press in the new balljoint.
Look at this other thread here on the XK subforum. Here is the weblink:
https://www.jaguarforums.com/forum/x...l-joints-5289/
Go down to post#45 - Good information from another forum member that had your same problem.
Jim Lombardi
Jim Lombardi
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
stanjag
08-30-2015 10:35 AM
