Need parts / advice for 2000 XJ8
Old 09-19-2011, 02:37 PM
george82's Avatar
Cool Need parts / advice for 2000 XJ8
Hello friends!
My 2000 XJ8 won't start. A local mechanic told me that the alternator, battery, and brake pads/brake rotors all need to be replaced. It's a right-hand drive by the way.
Could you please share some advice, about getting either used parts from someone else in the forum, or a recommended trustworthy website for ordering all of the above?
Thank you so much!
Old 09-19-2011, 03:57 PM
Received 2,190 Likes on 1,357 Posts
Check rockauto.com, or partsgeek.com both good n cheap. Alternator???? Really!!! Theyre pretty expensive cause they rarely fail. I would go more battery, bulkhead fitting in engine compartment, and or ground strap(engine to chassis)
Old 09-20-2011, 04:00 AM
Cadillac's Avatar
Yuo can try our vendors , since you're a forum member you can also get some discount
www.gaudinjaguarparts.com
NALLEY JAGUAR
Other sources
www.jagbits.com
www.motorcarsltd.com
www.autoanything.com
Old 09-29-2011, 12:17 PM
george82's Avatar
thank you very much!
I found five different alternators in rockauto.com, does anyone have any suggestion as to which model to choose?
Old 09-29-2011, 08:09 PM
jimlombardi's Avatar
Received 1,621 Likes on 874 Posts
Hi
I found another forum thread where the Alternator parts were found and used to rebuild it:
https://www.jaguarforums.com/forum/x...ild-fyi-58290/
The reason I thought to research the parts available for X308 (XJ) was that I have had the good fortune to be able to replace the brushes in the alternator for our 1990 Acura Legend.
The snap-in set of brushes are available at our local Acura dealership.
It does sound like the Jaguar is as easy as the Acura alternator fix.
Jim Lombardi
obwoodie
09-03-2015 07:45 PM
pocketrocket
09-03-2015 07:44 PM
hafren
09-02-2015 06:22 PM
XFR_Gold
09-02-2015 12:24 PM
innzane
09-02-2015 10:08 AM
Quick Reply: Need parts / advice for 2000 XJ8
