Oil Leak from top of engine
I have oil residue around the oil cap, the crankcase vent hose, and the little sensor next to it. (Sorry, don't know the proper names on a Jag.) Oil is backing up into the air intake housing, and I'm adding a about a quart every 2000 miles. Does anyone have an idea of what to do about this? It seems pressure is coming from somewhere and pushing the oil out of these places, but not sure where to start looking. Thanks
2000 xj8 95k
2000 xj8 95k
Received 2,193 Likes
Check out this thread: https://www.jaguarforums.com/forum/x...r-filter-9655/
On the first page you'll find a reply from me with pictures about how to clean part load breather.
The size you have given to clean the Part Load breather is too large and will affect slow running.
The correct size is 2.5mm or 0.09843"
PART-LOAD BREATHER CLEANING Photo Gallery by Max Heazlewood at pbase.com
Cheers,
Maximus
2000 xj8 95k
2000 xj8 95k
Apart from the points already mentioned, you may be well advised to have a 'blow by' test performed on your engine.
I say this because adding a quart every 2000 miles is far from normal with these engines.
What sort of service records are with this car?
How often is the oil and filter changed?
Cheers,
Maximus
BrentGardner
28
04-26-2024 03:08 AM
rusty37
06-07-2016 04:43 PM
