programming a TCM module for a x308 XJR
I did a succesfull "re-learning" on my '99 XJR some days ago (Mercedes trans).
My issue was upshifting on low rpm's , and only downshifting with full trottle while overtaking (normal mode).
(EDIT: I did not reset anything)
- First accelerate with light (constant)throttle in "2" till 2400rpm , release throttle and back to about 1000rpm.
Repeat minimal 4 times.
- Do the same in "3" and "4" . Try to stay in 3rd gear when in "3" , same in "4".
- Stop the car and let it idle in "P" for min. 10 minutes. (storing)
This did the trick for me , the car is now upshifting on higher RPM's , and feels fast again.
The 10min. idle storing sequence is tricky , what if you are in a traffic jam for more than 10min. ?
Or as i did , an engine flush with 20min. on high idle ....
jonathan.relentless (10-24-2013)
I posted a PDF with 722.6 adaption info in post #49 of this thread :
https://www.jaguarforums.com/forum/x...d-58651/page3/
I used the bottom part of the discribed info.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 12:09 PM
al_roethlisberger
09-07-2015 11:53 PM
