radio removal
put it in neutral ..j-gate shifter surround.. popps up straight.. becareful no to brake it.. once off then there is 2 7mm nuts and 2 7mm bolts.. remove.. then remove plastic trim that holds the sports button.. unplug.. and take out.. then push metal plate that the nuts bolt on to forward.. and down.. then lift wood ski slope.. up from the bottom.. and then out.. but carefully.. this can be fragile.. once out.. couple phillips screws and the radio is out.. the tabs that the radio uses to screw down .. can brake.. so be careful with them.. and make sure you have the radio code.. if disconnecting the radio
good luck
good luck
