seats not working
Operation is controlled by a module located under the front edge of the seat. It is easily removed by removing a couple bolts and the two connectors. Test procedure is to swap modules with the other seat and see what happens. If you have two failed modules I would suggest looking for an used one as they are incredibly expensive at the parts counter. Try car-parts.com and remember that used parts prices are fully negotiable. I got one shipped for under a hundred dollars. A common failure point is a circuit board line at the edge of the board that is rubbed by the plastic housing. Many have been able to repair with a small soldering iron.
If that doesn't solve the problem look to the switch pack on the side of the seat. I took one apart and resolved a connection problem .
. . . and welcome to the forum!
Welcome to the forum
Make sure all the motor cables are plugged into their sockets
Here is information on the Front Seat switchpack fuses & Relays.
Check that fuses are not blown:
Fuses for Front Seats
Passenger seat switchpack – Healboard Fuse Box – Right hand side - Fuse number 9 -- 5 AMPS
Driver seat switchpack – Healboard Fuse Box – Left hand side - Fuse number 8 -- 5 AMPS (Fuse 8 is also shared with Steering column adjust switch)
Front Seat Relays are located under each front seat (for that seat).
Here is Front Seat Recline Motor R&I forum thread (see post# 1):
https://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/front-seat-recline-motor-r-i-58392/
Here is a PDF file for R&I of the Front Seat Track Motor:
1999 XJ Front Seat Track Motor R&I.pdf
step# 15 seems to be a little extreme -
Since you have less than 10 posts, you will not be able to open the file attachments (including this PDF file) while you are logged into the forum. Logout when you want to open a file attachment (guests are able to open file attachments). After you are finished with the attachments, log back into the forum.
Look at the posts in this forum thread:
https://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/power-seats-not-working-16455/
Jim Lombardi
15. Position slider/motor assembly and seat frame for access and drill out pop rivets securing LH slider to seat frame.
Jim Lombardi
philwarner
09-05-2015 10:05 AM
