Sliding Roof Removing/Adjusting/Installing
Old 09-18-2013, 08:36 AM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default Sliding Roof Removing/Adjusting/Installing
I created a new PDF file from the JTIS software that covers Sliding Roof Removal, Adjustments, and installation.
The PDF is 20 pages.
Here is weblink to the PDF file - my dropbox account:
https://www.dropbox.com/s/p9muq4aeoe...20Panel%20.pdf
Jim Lombardi
The following 4 users liked this post by jimlombardi:
joe01952 (09-18-2013), jrb53 (05-04-2016), NTL1991 (12-15-2014), Topcroc (09-23-2013)
Old 09-18-2013, 03:27 PM
joe01952's Avatar
JIm
Thanks for the write up
Im going to take a look tonight might be back with questions
Thank You
Old 09-18-2013, 08:00 PM
joe01952's Avatar
clicked iin!! great....even slides...lol
thanks
Old 09-19-2013, 05:43 AM
joe01952's Avatar
WAIT JIM!!!
so excited getting the large inner panel in , what for the smaller rectangular hook on to if any thing?
Old 10-12-2021, 12:45 PM
schablam's Avatar
I just took a sliding roof out of a junked car this weekend. MY BIGGEST TAKE AWAY: cut the rubber hoses to the drains first thing.. I left the back ones on and when I fully unbolted the roof, the weight of it coming down in my hands broke the rear plastic drain guides, leaving the nozzles broken off still in the rubber drain tubes. I guess I thought that the tubes would pop off instead of breaking the plastic drain guide off. I thought wrongly.
Other wise it was pretty easy. I dont know if I can somehow make new drain guides, and silly me left the broken plastic tips dangling there in the rubber tubes still in the junked car, (2 hours away mind you)
I did learn that I can probably make my sunroof not "leak" by retrieving the rear water tray that I thought was just a piece of trim for cosmetics. It is stuck back on the sliding roof rails.
I primarily wanted to get a look at some of the small plastic pieces to see if it would ever be possible to get some made after market.
1983turbojaguarxj6
02-07-2019 07:23 PM
philwarner
28
07-11-2017 10:21 AM
NTL1991
XJ40 ( XJ81 )
05-01-2017 07:54 AM
Delta66
10-04-2015 05:40 PM
Quick Reply: Sliding Roof Removing/Adjusting/Installing
