Starter removal help
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi, I need to replace the starter on my '99 XJ8. Saw the post elsewhere regarding starter removal, but I have two questions:
What is a "U.J"? (The upper bolt may be removed (after loosening) using a 3/8' square drive 13 mm socket, extensions and U.J as shown.)
Any advice on how to access upper starter bolt? Will the half moon wrench take care of that problem?
I really don't plan on removing the steering rack.
tia
tia
Hi
The U.J. is the abbreviation for Univeral Joint tool (also know as a ratchet swivel flex universal joint extension).
This jpeg shows this tool attached to a rachet, the extension bars, the swivel, and the socket all assembled to give access the upper mounting bolt of the starter. Also a close-up of the swivel flex universal joint extension.
Here is information from the JTIS:
Remove the starter motor securing bolts.Remove the upper securing bolt. Preferably, use a short 13 mm spanner or a Snap On Half Moon spanner CMX1113 to initially loosen the bolt.
![Name: ratchetswivelflexuniversalextension.jpg
Size: 11.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/168615d1501280699-starter-removal-help-ratchetswivelflexuniversalextension.jpg)
I think to 300 length is 300 mm or about 11 inches, and the 140 is 140 mm or about 5 1/2 inches.
Hope this helps
Jim Lombardi
Hope this helps
Jim Lombardi
TheBrightKnight (07-22-2012)
aholbro1
08-05-2021 05:02 AM
1964Daimler
09-09-2015 11:28 AM
