Timing Chain Total replacment
I posted about 6 months ago that my secondary tensioner are in need of replacement. Well the car is untouched, it hasn't been started or moved in 6 months. I was toying with the idea of getting rid of it and getting a newer car and not deal with the timing chains Etc. The car has 104k and figured might as well change the whole thing, which came out to about $750 ruffly( reason for long wait). Well i decided to tackle changing the whole assembly myself. I'm fairly mechanically inclined changing part, i never got deep enough to redo a top end etc. But got pretty good taking stuff apart and replacing. My question is do i have a chance fixing it myself or is the job to hard??? What tools needed?? Anyone find a good place for the complete kit?? Any How to threads??? Thanks
There are many threads on tensioner replacement. I never had worked on an overhead cam setup but found nothing difficult in replacing the secondary ones. Removing the crank pulley would appear to be the most difficult issue and that is solved by using a longer piece of pipe on your breaker bar. You will need the cam timing tool set that can be rented. I suspect that you can beat the price by half of what you quoted by using the Lincoln LS parts.
What model year is your car? It would help to include that information in your signature or at least in the post.
Here is my 'library' but I am sure there are lots more out there.
Cam Chain Tensioners - Removing Valve Covers Only
https://www.jaguarforums.com/forum/j...17/#post316489
Help - sudden fail - Jaguar Forums - Jaguar Enthusiasts Forum
I just changed my own timing chain tensioners........ - Jaguar Forums - Jaguar Enthusiasts Forum
Ford tensioners for Jaguar??? - Jaguar Forums - Jaguar Enthusiasts Forum
Tensioners, when are they a "must replace" item? - Jaguar Forums - Jaguar Enthusiasts Forum
Free File Sharing Made Simple - MediaFire
DIY ~ Jaguar 4.0 (R&R) Timing belt, Tensioners, Water Pump, etc. - Calguns.net
Cam Chain Tensioners Lincoln LS Part Numbers
https://www.jaguarforums.com/forum/j...34/#post330655
JTIS .pdf files on Chains/Tensioners replacement
https://www.jaguarforums.com/forum/j...prokets-54603/
Cam locking tool dimensions
Welcome to Jag-lovers - Members Photo Viewing Page
Cam Chain Tensioners Cam Removal Method 2nd tensions DIY instruction FAQ - Jaguar Forums - Jaguar Enthusiasts Forum
Broken Cam Due to Removing Cam
Cam shaft woes - Jaguar Forums - Jaguar Enthusiasts Forum
The following 7 users liked this post by test point:
Boomer from Boston (01-14-2012),
Cadillac (01-14-2012),
JimC64 (01-14-2012),
jimlombardi (01-14-2012),
Norri (01-14-2012),
and 2 others liked this post.
Sorry need to make my sig. It's a 1998 XJ8, while im in there i was thinking of changing the water pump and thermostat. Still think its the original ones. Car has 104k, reason for me wanting to redo the everything instead of just the secondary tensioners. Thanks Test, you're always there when in need
Found this guy and he sells the kit for 650. Also rents ALL the tools for 75 bucks and has a video that will help some.. What do you guys think about him??
JAGUAR V8 TIMING ALIGHMENT TOOL SET,1997-10 DELUXE KIT | eBay
The following 2 users liked this post by Jomax:
Barbs cars (06-05-2013),
Rlover (06-10-2012)
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
