Valve (Cam) Covers R&I JTIS21 Extracts
Hi
I thought this would be a good time to give information about how to proceed if you cannot find a particular repair information in the JTIS21 for your model year.
Most of the Engine repair information for 2000 thru 2003 XJ series model is in the 1999 XJ Engine (In Vehicle Repair) Section of the shop repair manual. Whatever it is not in 1999 XJ section then it is most probably in 1998 XJ section.
When I say most, I am referring to the external engine parts and internal parts (camshafts, timing chain, crankshaft seals, oil pump, oil pan, valve covers, etc.)
Here is the Valve (Cam) Covers R&I (and the other related R&I steps required):
1999 XJ Valve Cover LH R&I.pdf
1998 Jag XJ Ignition Coil-On-Plug LH R&I .pdf
1999 XJ Evaporative Emission Canister Purge Valve.pdf
1999 XJ Valve Cover RH R&I.pdf
1998 Jag XJ ignition Coil-On-Plug RH R&I.pdf
Jim Lombardi
Jim Lombardi
aholbro1
08-05-2021 05:02 AM
Dickie_L_J_O
09-13-2015 07:44 AM
