XJ Range Instrument Cluster R&I FAQ
Old 07-15-2011, 06:39 AM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default XJ Range Instrument Cluster R&I FAQ
Hi
Here is XJ Instrument Cluster Removal & Install extract from JTIS21 Shop Manual:
XJ Range Instrument Cluster R&I.pdf
XJ Range Instrument Cluster Finish Panel R&I.pdf
First you have to remove the Instrument Cluster Finish Panel (the wood veneer) - you need to grab it hard from both ends and pull it towards you to release the retaining clips.
Also be careful when you come to the step of removing the 2 harness multiplugs - they have a locking lever system -the lever tab locks over a higher protruding part.
I broke both of the locking levers when I had a hard time trying to get them to move (they still hold the connectors together, but no longer lock).
Here is a photo of the Instrument Cluster that shows the 2 Harness multiplugs:
https://www.dropbox.com/s/kxro2g0v8q...Multiplugs.JPG
Jim Lombardi
Last edited by jimlombardi; 02-13-2013 at 10:33 PM. Reason: Added photo of the Instrument Cluster (shows the 2 harness multiplugs)
The following 4 users liked this post by jimlombardi:
adriaxj8 (03-29-2012), Alvin Burns (12-22-2012), milkman (07-30-2014), xjay8 (05-05-2013)
Old 07-16-2011, 02:50 AM
Cadillac's Avatar
Thanks , will FAQ
hkmcmast
11-29-2015 06:56 AM
inactualis
10-02-2015 11:13 AM
Glenn Barickman
10-01-2015 04:09 PM
reb1999
09-26-2015 08:41 AM
Quick Reply: XJ Range Instrument Cluster R&I FAQ
