XJR Transmission fluid
Old 09-10-2011, 04:51 AM
Sean B's Avatar
Received 1,363 Likes on 1,072 Posts
Originally Posted by adam699
I wonder If I could use my durametric from the Turbo to reset adaptations on the Jag trans....hmmm
What can you alter with the durametric? shift points? shift times? Or is it a reset, because a hard reboot can do this.
  #42
Old 09-10-2011, 12:42 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Thumbs up
Originally Posted by avos
The results are that in very low torque shifts, it is perfect (so not bumpy), but the higher power shifts are less firm then before. But still firmer than the original solenoids
Sounds like you have achieved a perfect upgrade in the driving experience and improved durability.
Given that this thread may become the canonical thread for the solenoid upgrade on Jaguars running the W5A580 transmission, the major parts of the procedure are:
1. install solenoids
2. reset tcm, probably by full powertrain reset as described elsewhere since most people will not have a spare tcm
3. enjoy
  #43
Old 09-11-2011, 08:30 AM
Sean B's Avatar
And may I add, do a partial fluid change, with new pan gasket, bolt and copper washer, and filter. Doing mine this week ;'0
  #44
Old 09-11-2011, 10:09 AM
plums's Avatar
The partial fluid change is kind of unavoidable unless one recycles the atf drained to drop the pan
Make sure you pay particular attention to step 3 above: "enjoy"!
  #45
Old 09-11-2011, 10:25 AM
Jaxkr's Avatar
I replaced the solenoids on my car a few weeks ago, what a difference. The other thing you want to change is the connector for the plug in the transmission. I purchased the pan gasket & plug from the local Mercedes dealer for $45.00. The solenoids are not cheap but make a huge difference in the shift quality. Here is a link on the installation.
Feedback/How to: Install SHR Shift Improvement Solenoids - Lx Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum
I was shocked at how much cheaper the parts were from Mercedes, they are half the price I would pay as a dealer employee.
  #46
Old 09-11-2011, 10:35 AM
plums's Avatar
It's the same situation with Jaguar .. they source the parts from Mercedes and then apply a markup.
  #47
Old 09-11-2011, 10:47 AM
plums's Avatar
BTW, that car is running 9.59 @ 148
One other thing while under the car ... seal the dipstick tube at the transmission with RTV. There is a Chrysler TSB out on this because water seepage at this joint can cause slippage at concentrations as low as .05 percent. The TSB calls for the RTV and a TRIPLE flush of the ATF once water gets in.
  #48
Old 09-22-2011, 04:25 AM
Sean B's Avatar
Just bought a super cheap low miles 722.6 out of a 98' UK XJR......it's cheap because the fool that dropped it didn't take the torque converter with it......
Can anyone tell me anything about the early MB boxes compared to the later, say 01/02?
The one thing I've come across is the drain plug on the early torque converters, is there anything else, like bearing updates etc on the later boxes? I'm about to install blue top solenoids in it, then fit it to my rebuilt motor.
  #49
Old 10-19-2011, 03:27 AM
popeye68's Avatar
Here's some 722.6 shift adaptation procedure info
MB 722.6 Shift Adaptation Procedure.pdf
plums (10-19-2011)
  #50
Old 10-19-2011, 03:37 AM
plums's Avatar
Attachment 13728
Nice to know.
  #51
Old 10-20-2011, 10:08 AM
pdog2000's Avatar
popeye 68..thanks for posting...i've been trying to find the adaptations for the XJR tranny for quite sometime
  #52
Old 10-20-2011, 06:25 PM
plums's Avatar
If any one is looking for the service manual published for the LX using this transmission, you can find it by using the search term:
+"automatic transmission nag1 - service information"
in a search engine.
Sean B (04-12-2012)
  #53
Old 02-25-2015, 11:42 PM
erick_151's Avatar
Default ATF Necromancy
Not sure if this thread made it to cannon or not, but seems legit as anything I came across so apologies for the necro.
I'm looking for the latest info for my 1999 XJR. Ready to do a fluid exchange, and thought I was good to go, but the seller cancelled my order of this: http://www.ebay.com/itm/351319490140
And said I needed to order this instead: http://www.ebay.com/itm/361226082235
Any suggestions on this would be appreciated.
I already purchased the connector plug, but I would also greatly appreciate help sourcing the blue solenoids.
Thank you much!
  #54
Old 02-26-2015, 08:56 AM
RJ237's Avatar
Received 2,815 Likes on 2,244 Posts
You will find that not many members read/respond to old threads. Starting a new one will get more response. The mercedes transmission uses ATF 123. If you don't have a dipstick kit, you will need that, also.
  #55
Old 02-26-2015, 03:26 PM
vincent661983's Avatar
the tranny uses M Benz ATF, not hard to find
check ebay or amazon
  #56
Old 02-26-2015, 03:27 PM
I changed it twice in 3 years already( once because I had to repair some tranny issue)
  #57
Old 02-26-2015, 05:36 PM
JWT's Avatar
JWT
JWT is offline
Default Valvoline Maxlife Dex/Merc
For what it's worth, I put Valvoline Maxlife Dex/Merc in my 98 XJR transmission about 45,000 Km ago. No issues to report. I also called Valvoline prior to using it and they assured me it was a good choice. I bought it at Walmart.
I mention this because it seems some members are struggling to find transmission fluid for the Mercedes units in XJRs.
Other members may shudder to think of using oil purchased at Walmart, but I have been quite pleased with how it performs. 45,000 K may not be a torture test, but no signs of concern have been detected.
  #58
Old 02-26-2015, 11:45 PM
erick_151's Avatar
I want to get closest to stock atf as possible since I'm not doing a full flush. Just a drain and fill. Don't like the idea of mixing different fluids,... I thought I read the original spec was 236.10.
What's my best bet considering the above?
  #59
Old 03-02-2015, 04:02 PM
  #60
Old 03-06-2015, 12:45 AM
erick_151's Avatar
Default Give up
Think I'll just go with some Fibi Bilstein 236.10 Spec.
Thanks.
Quick Reply: XJR Transmission fluid
