XJR Wiper Problems
Hello, I just bought a 1999 XJR and am currently troubleshooting the windshield wipers. They will come on, but will not stop with the wipers switched off - eventually they will stop, the intermittent feature will work occasionally too. I have swapped the wiper relays, no help, I checked the wiper motor park switch for continuity, it's good. Any ideas?
Haven't heard of this problem before, so just guessing....
If the wipers stay on longer than you turn them on for (but do eventually stop) I would suspect something to do with the stalk switch on the steering column sticking in the on position for a while.
Also, you have a rain sensing wiper system..... are you having problems when you have the wipers in manual mode or in rain sensing (auto) mode ? (This may provide additional info for the Jag Techs who will hopefully pick up this thread soon)
My wifes 02 XJR had the same problem. It WAS the relays. I would double check them. When a relay sticks in the on position it is one of two things, either the control power isn't removed by the switch or the contacts inside are burned and sticking.
Connect a volt meter to the control side of the relay. Start the car and turn on the wipers. What ever the voltage (should be 12v) this is your control voltage and should only be present when the wipers are turned on switch on the steering column.
Now with the wipers still on move the meter to the output side, this will show power going to the wiper motor. Should also be 12v.
Now shut off the wipers. Relay should open removing power to the motor. If wipers still on then check the control voltage again. If the control volage present then most likely the switch. If control voltage is 0v the the relay is sticking.
Yo, SARC - If I recall correctly, rain-sense was an option from 2000-2003 (USA year designation, and US spec cars), may have been standard on VDP those years? Definitely was not available here 1999, as I tried to get them when I ordered my XJR (January 1999). 2004 and up all have it.
Kinda odd - I wanted headlight wash, too - it was standard on Canadian cars and not available US....
________
1999 XJR
________
1999 XJR
Received 2,191 Likes
Brutal, I see you mentioned the park switch located in the motor. Admittedly, I haven't gone out to look at my motor before asking this question. To clarify, is this switch internal where I'll need to remove motor then switch? Or located exterior. And last dumb question, can I get switch from dealer without buying entire motor? My wiper exhibits the same erratic behavior. Most of the threads mention the relays, of which I've yet to try also.
Thank you for your assistance.
Ralph
Ralph
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
