Arnott Coil Conversion Kit
Hey, new member here. I just got my 2004 VDP back from getting the suspension replaced with the new Arnott coil kit. I think it was just released today.
JAGUAR Air Suspension Parts - XJ Series 2004-2010 XJ Series
So far, so good. If any issues arise, I'll report to the forum.
If you are in the Austin, TX area, I had it done at Luxury Auto Works. The owner, Thomas Dere, is a straight-talking, good guy. Apparently, he was very impressed with the kit.
I am very curious to know your impression of the ride characteristics, especially if you owned the car for a time before having the coil over kit.
Do you notice any significant differences in ride, handling, reaction to road imperfections, etc?
This information could prove valuable to many here. Thanks for any input you're willing to give us.
Unfortunately, I have no point of reference - I acquired the car about two months ago and all four original shock bags and the compressor were shot.
I knew I had to replace the suspension when I bought it, and used it as leverage at the dealership to get a great deal.
If anyone in the Austin, TX area wants to compare rides, I would welcome the opportunity.
I just read the installation instructions for this. It tells you to remove the ASM and tie the wires. No word of any new modules or programming to eliminate erroneous messages. I would assume you could remove the air system unless you wanted to retain it for tire fill.
Brutal, have you seen this conversion?
The other coilover system is twice the price. Plus they are very secretive about some "module" that must be added to keep the computers happy.
The Arnott system implies that you just do away with the ASM. Brutal says it must be retained. I tried calling Arnott's tech support but got no answer.
If I get one more bag failure I will go to coilovers.
![Icon Werd](https://www.jaguarforums.com/forum/images/smilies/icon_werd.gif)
I'm leaning this way, when I start having hissy failures, but only if I can verify that I won't suffer a tangible degradation in ride quality and handling characteristics.
I frequently drive my XJR shall we say, enthusiastically, and I love the ride the air suspension provides. Jaguar deliberately went to air suspension for the weight reduction changes in ride characteristics that lightening the chassis accomplished in the X350 over the X300. I don't want my Jag riding like a Crown Vic on the one side, or a lowered Mustang on the other.
I confirmed with my mechanic that the ASM is removed with the Arnott coil conversion.
So, some people think the ASM is necessary for other functions? Like what? Perhaps ASM is a bit of a misnomer.
This forum rocks. I've already been able to correctly diagnose issues thanks to the info posted here.
Received 2,192 Likes
Well i for one thought the asm needs to stay in the network since its on the can network and other modules look for its info. But maybe its legged in like the cats system on the stype. If you remove that module the system just thinks it not equipted and ignores the missing module. Now motorcars system retains the module and supplies resistor pins to duplicate the shocks resistance to the module and retain the module, so i would have assumed they found out it needed to be retained, evidently not. And of course their system is twice the money.
I had a chance to open her up a bit on some hill country roads last weekend, and I'm impressed so far. But, as stated earlier, I have no point of reference.
I'd like to think there is an easy manual adjustment. Hmmm... checking around now.
I saw this posted elsewhere:
"* The headlight leveling system was eliminated from the X350 during the 2005 MY, starting at VIN G39155 onward.
The system was deemed unnecessary due to the self-leveling capabilities of the air suspension system.
The later wiring diagrams still show a 'Headlamp leveling module' so who knows?"
My 04 VDP still gets the rise and fall of the xenons, so should I assume I have this leveling system (albeit some manual hex bolt tinkering could help raise them to where I want)?
If so, the ASM may not be necessary.
