howto get rid of rpm hunting / surging on warmup
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Hi,
after reading all threads about that annoying "rpm hunting" many of us experience during warmup, I'd like to share the results of my investigation.
How does the torque converter lock ?
There's a valve no 6 in the gearbox, which drives the clutch for locking.
To avoid vibration from the turbine, it's a "unperfect lock" with a slight slipping achieved by the TCM in regulating that valve.
When the oil gets warmer than 30° (cel), the locking mechanism starts.
What is the problem of hunting ?
My measurements showed the TCM slowly decreasing the pressure on valve no 6 when suddenly the turbine's rpms increased, while the gearbox output rpms remain stable. The TCM recognised that problem and increased the pressure.
Hunting is basically a combination of the TCMs software, the cold oil and probably some wear within the gearbox.
Howto get rid of hunting ?
In a german BMW-forum, I read the same issue of 6HP26 and I read about a sw update of TCM that raises the locking temperature to 40°.
Although my car was serviced by jag dealers for more than 8 years, all software was dated 2002/2003. So I updated my TCM ( which took 30min and showed all possible signs of a bricked car while flashing
) , I cleared the adaptations and I drove that adaption cycle.
Seems like hunting is gone now ... as I did the adaptation cycle allready bevor TCM update, I'm sure, the sw update was the point. My TCM sw is now dated 2005.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
The following 4 users liked this post by nebelfuerst:
I bought a mongoose cable and the SDD-Sw.
As I don't have access to engineeringmode or coded access, I put in some symtomes about gearbox. So I found a menu to update an existing or new TCM.
Afterwards you'll have to clear TCM adaptations and drive the cycle.
My hunting is not 100% gone, but it is so litte, that my passengers don't notice it any more.. but I do.. as I became very very sensitive ,
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
Chuck Schexnayder
33
10-24-2015 10:20 PM
