obd2 port location? Help please
I'm trying to find the obd2 port location on a 2007 xj8 Vandenplas. Would someone lead me in the right direction.
I've looked under the left and right side of the dash. I have removed the cover under the steering wheel and looked inside. I looked under the hood and in the trunk. Also, in the glove box and center console. I looked in the manual. I know it's in an easy to find location. Right?
Any help will be appreciated.
The following 2 users liked this post by dsetter:
danveenstra (02-08-2015),
NEV3 (03-01-2015)
Received 9,010 Likes
Same for me but opposite sides on a RHD car....
Not easy to spot immediately, but a clsoer inspection and there it is.
The following 3 users liked this post by JimC64:
Maybe a picture would help for the USA XJ8.
The first picture it would be in the very right lower corner at the end of the dove color trim and in the second picture you can see the OBDII port. You really have to get your head down into the floor area and look staight up to see it.
The following 3 users liked this post by lcmjaguar:
It took me about 10 minutes to find it the first time and even knowing where it is it is not the easy to plug into. I had to show the DMV inspector where it was.
Just below the key switch behind the valance in the corner next to the console. The port is facing down with the shorter of the long sides of the connector facing aft
The following 2 users liked this post by Clamdigger:
ShockandAWD (07-07-2024)
Excellent. Thank you for the pictures lcmjaguar. Worth a 1,000 words, right? That's exactly where Don B. said it was. Again, thanks for your help. Dan Veenstra
A note to all - It's things like this forum that renews one's faith in that folks really do want to be helpful when someone is in need. I've also made contributions in the past and am pleased to be a part of this Jaguar group.
Don B (02-08-2015)
jimforrest (uk)
02-28-2019 06:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
