Official ZF Transmission 6HP Series Service Video
Old 04-05-2014, 03:25 AM
SaturnV's Avatar
Default Official ZF Transmission 6HP Series Service Video
I don't recall having seen this one posted, so here goes. This covers the basics for a straightforward fluid change. The video gives a warmup temperature to check the fluid at between 30º and 40º C. Also shows the torque sequence for the pan. I went ahead and snapped a screencap of the illustration.
Hope this helps someone considering doing this service themselves.
Attached Thumbnails Official ZF Transmission 6HP Series Service Video-zf-transmission-pan-torque.jpg
The following 7 users liked this post by SaturnV:
alanroberts50 (04-20-2014), Clamdigger (04-05-2014), jjd247247 (02-21-2015), lcmjaguar (04-05-2014), Partick the Cat (04-05-2014), paydase (04-05-2014), xjay8 (04-06-2014) and 2 others liked this post. (Show less...)
Old 04-05-2014, 05:23 AM
paydase's Avatar
Thx, very useful.
Good to see that ZF provides this clear info.
Maybe worth also to change the small diameter nuts of the pan during the process (and hoping no seizyre issues of sare encountered to remove them!)
Old 04-06-2014, 05:43 AM
nebelfuerst's Avatar
Very helpfull video, thanks.
Does someone know, how much fluid is necessary on a XJ8-gearbox changing like to guy in the video does ?
Is 6 liters also applicable to a jag ?
Old 04-06-2014, 06:25 AM
xjay8's Avatar
These boxes are just like the X308....there 'dry' spec is 10 litres and a normal drop and fill will take up to5 litres.
Old 04-06-2014, 06:29 AM
xjay8's Avatar
Good info and yes, it's almost similar to the proceedure for the 5HP24 box on our cars...should have had an X350 up on the hoist ;o))
Oil level check is the same....30.C is the lowest and 50.C is the highest.
Above thjis and the box must cool down to between spec. temps.
Lifeguard-6 is the preferred oil for these.
bamforp
Yesterday 05:36 PM
ahunt4
09-14-2015 08:17 PM
Jaguar Forums Editor
Jaguar Press release
09-04-2015 09:18 AM
Jag-o-nomic
09-04-2015 03:07 AM
09-03-2015 09:38 AM
Quick Reply: Official ZF Transmission 6HP Series Service Video
