P0171 Code Resolved
Ok. Had a P0171 Lean Bank 1 Condition. Thanks to the forum members for all the knowledge acquired here. I am posting my experience in the hope that it may help someone else deal with P0171.
First option was to replace the O Rings on the PCV valve and associated hose. This area was scrutinized as these areas seemed to hiss. Anyway O Rings did not fix, so replaced PCV. Here are some pics of this process.
brakeboost (05-09-2014)
Fuel filter replacement up next. This was straight forward, thanks to the advice in de-pressurizing the system so as to not 'wear' a bunch of gas from the filter exchange process.
Anyway, here are a few pics of the event.
Again, this did not resolve the reoccurring code, but at least the fuel filter is renewed at 83,000 miles...
So, in the meantime I ordered an elm327 bluetooth obd2 device online. An installed the Torque app on android tablet. This way, I could view real time data and did not have to borrow code reader from coworker.
Here's a shot of LTFTs in action...note this shows post-repair LTFTS reading 14.8.
So, took this in for some professional help, who hooked it up to the smoke machine and Voila!, a thin, 'birthday candle width' of smoke rising from the rear (left) passenger side of the engine bay. Apparently, a plastic 'hose joiner' had cracked.
Here is a pic of it in two parts as it snapped fully during removal. And NAPA had the replacement...
Since this time, have done four - 150 mile trips and no code.
Have been having trouble with the portable app lately, so have not been posting. Deleted and reinstalled and all appears well...
Also, after each maintenance described above, I did clear the code and reset ECM using the battery terminal ground process.
Thanks again, hoping this helps the next driver with a P0171...
-mag
-mag
The following 6 users liked this post by magmedia:
AD2014 (05-07-2014),
Clamdigger (05-09-2014),
etaent (03-15-2015),
meirion1 (05-09-2014),
MgkMkr (08-17-2014),
and 1 others liked this post.
Yes, that was the only code found with scanner.
Thanks-
mag
Both banks?
Does it drop at 2500-ish rpm (hot engine, parked)?
