Phone trouble
Phone trouble
Hello,
I recently installed a PSE and bluetooth module (both are of the correct, and updated serial number range). I installed the external microphone also. I then put the head unit in discoverable mode, and was able to easily pair my iPhone with the system.
I could use the system to make calls, however, no one can hear me talking! I can hear everyone just fine over the cars speakers, but no matter what I do, I can not be heard! I have done a hard re-set on the system (disconnecting the battery and letting it sit for 15 min), paired and unpaired the phone, tried another iPhone, and nothing seems to work. I have checked all of the connections and everything is correct.
Any ideas? Defective microphone?
Thanks for the anticipated help.
Chris
Chris
cjaekl,
I hope someone else will chime in as I have the same problem as you. I am bringing the car in on friday to have it reprogrammed to get rid of the CONFIG B error that I've been getting since I added the phone module a few weeks ago and I hope that will cure the microphone problem.
Mat
Mat
Went and talked with the parts guy at the local Jag dealer yesterday. He had absolutely no idea what I was talking about when I asked for a 3 pin bridge. I explained the problem I was having, and he still had no idea. Their thoughts are that my microphone is defective. Looks like I'll have to buy a new one and see how that goes.
cjaekl,
Your mike is fine the part number for the bridge is XR843781. I picked mine up from the dealer last week and it fixed the problem we both had. I paid $50 with tax for it but I just looked on http://www.gaudinjaguarparts.com and they have it for $27.28 plus shipping so if you want to save some money go through them instead of your dealer parts dept, when you put in the part number its listed as lead link. The only problem that I am getting now is a CONFIG B message on the dash 9/10 times when I start the car. The dealer tried reprogramming the car but they said they couldn't get the phone module to flash, but that was before I added the bridge to fix the mike so maybe they could program it now?
Good Luck,
Mat
Good Luck,
Mat
I think there are several revisions of the PSE module - inticated by the last two letters (AB, AC, AE, BA, etc.). Some old revisions are not compatible with the blutooth module for some reason.
I think I have revision AE and it works, yours may be too old. Unfortunately the fix is to get a new-er PSE.
The Jag diag software is a bit funky. There is a thread about it in the general tech area (https://www.jaguarforums.com/forum/s...ad.php?t=32683).
