Rear Wheel Bearing, need a bit of help
Old 12-31-2009, 05:43 AM
StrateLoss's Avatar
Default Rear Wheel Bearing, need a bit of help
Hey everyone, my 2004 XJ8 is pretty noisy from the rear. At first I thought it was from the shot rear rotors, so I replaced both rotors and pads. Replaced all the brake fluid, bleed the system, reset the Parking brake.
With each job being completed, the noise levels came down. But it just didnt go away. I did a part search using google, the bearings came in at about $40 a peice, I'm assuming I need 1 per side.
Heres where I need help from anyone who has gotten their rear bearings replaced.
Do I need just the wheel bearings, or the whole hub assembly ?
Being a reardrive car, will the driveshafts need to be disconnected ?
Any special tools needed ? I did a site search and found that I may need an ABS ring removal tool ?
Again Thanks to any help in advance, Victor.
2004 XJ8 73,400 miles.
services performed by myself
Coolant Flush
Trans Flush
Sparkplugs Replaced
Rear Brakes Overhauled
System bleed
ThrottleBody cleaning
Maf cleaning
All coilpack connections cleaned
Breathers cleaned
Services to be performed
New front pads
Shaving front rotors
Trans pan and gasket
Trans flush
Rear wheel bearing/hub?
I purchased the car July 2009 with 69k miles, I need this car to last a long time and really want it to be in tip top shape so again any help with this rear bearing issue will be greatly appreciated.
Should I leave it to the pros or do this will my father ? My father is experianced with wheel bearings as he replaced them many times.
Old 12-31-2009, 02:30 PM
BuckMR2's Avatar
Replacement of rear wheel bearing 64.15.14
Had a look on JTIS and there are a number of special tools required
They are:-
Hub Puller 205-491
Adapter Nuts 205-491-01
Flange remover forcing screw 204-269
Rear hub support tool 204-249
Rear hub bearing removal tool 204-250
Front hub remover 204-193
Bearing support 204-252
IF YOU NEED ANY OF THE ASSOCIATED PICS TO ANY OF THE STEPS BELOW LET ME KNOW
REMOVAL
1)Loosen the wheel hub nut.
2)Remove the brake disc.
3)Detach the anti-lock brake system (ABS) sensor.
4)Detach the outer tie rod.
5)Detach the lower arm from the wheel knuckle.
6)Remove the wheel hub nut.
7)Using the special tools, detach the halfshaft.
8)Remove the wheel knuckle assembly.
9)Using the special tools, remove the wheel hub from the bearing.
10)Using the special tools, remove the inner bearing race from the hub.
11)Remove the circlip.
12)Using the special tools, remove the bearing from the wheel knuckle.
INSTALLATION
1)The final tightening of the rear suspension components must be carried out with the vehicle on its wheels.Using the special tools, install the bearing to the wheel knuckle.
2) Install the circlip.
3)Using the special tools, install the wheel hub to the bearing.
4)Install the wheel knuckle assembly.Tighten to 90 Nm.
5)NOTE
Using the old wheel hub nut tighten to 150 Nm.
NOTE
Remove and discard the old wheel hub nut, install a new wheel hub nut tighten to 150 Nm.
Attach the wheel knuckle to the halfshaft.
6)Install the lower arm to the wheel knuckle.
7)Install the outer tie rod retaining bolt.
8)Install the ABS sensor.Tighten to 10 Nm.
9)Install the brake disc.
10)Lower the vehicle.
11)Tighten the wheel hub nut.Tighten to 300 Nm.
12) Caution
The final tightening of the rear suspension components must be carried out with the vehicle on its wheels.Tighten to 150 Nm.
13) Caution
The final tightening of the rear suspension components must be carried out with the vehicle on its wheels.Tighten to 55 Nm.
The following 2 users liked this post by BuckMR2:
Johnken (06-11-2017), paydase (04-15-2017)
Old 12-31-2009, 05:37 PM
StrateLoss's Avatar
It seems that I would need a bearing press, a tool to remove the ABS sensor (as noted in first post), adaptors(I'm assuming for the bolts)
Seems like too much to do on my own on the street, I wonder what jaguar would charge for this procedure.
Does the JTIS give an ET for the job ?
Thanks I truly appreciate you taking time out to check this out for me.It seems with the weather cooler that it gets noisier and noisier.
Old 01-01-2010, 12:32 AM
BuckMR2's Avatar
Post
The JTIS doesnt give any times, I think you would need to ask a dealer how long they have the job listed at.
Old 05-05-2010, 11:04 AM
A14LN C's Avatar
think il b getting u to do my rear bearings Buck lol
Old 11-05-2011, 01:16 PM
rxp's Avatar
rxp
rxp is offline
They are:-
Hub Puller 205-491
REMOVAL
INSTALLATION
5)NOTE
NOTE
12) Caution
13) Caution
I have a 2004 Type-x 3.0 L 98k mi-- I would like to change the US front driver, bearing are the same tools and parts needed. I have found the bearing alone available or should I replace it with the armature assy?
Old 11-11-2011, 08:20 AM
Daimler68's Avatar
Default rear wheel bearing
hello ,
I did the job a few month ago , nothing difficult , no need of special tool to remove the ABS sensor
just usual extractor to remove the hub and the bearing
For an easiest fit , I put the aluminium hub in the oven ( my wife was not there ! ) to heat it to about 100 ° and the bearing just drop without any press needed
In my case the noise of the bearing was caused by corrosion on one side ( water should have go inside during a pressure wash
to be sure to locate was bearing make the noise it is better to put the car on stand and rotate the wheel by the engine
I thought from inside that the noise was at the right side , but was on the left !
Hope this will help
Philippe
jdzubas
10-04-2015 09:14 AM
Harry Dredge
09-03-2015 03:04 AM
Harry Dredge
09-02-2015 02:26 PM
innzane
09-02-2015 10:08 AM
Quick Reply: Rear Wheel Bearing, need a bit of help
