Trunk Actuator Lock
Old 10-09-2014, 03:45 PM
magmedia's Avatar
Default Trunk Actuator Lock
Bought a 2004 VDP and working through some of the issues.
Today's project- replacing the truck lock actuator.
Here are some photos.
Took about an hour, next time much less.
Thanks-
Mag
Attached Thumbnails Trunk Actuator Lock-image-3352511711.jpg   Trunk Actuator Lock-image-3972351153.jpg   Trunk Actuator Lock-image-2766151803.jpg   Trunk Actuator Lock-image-27541034.jpg   Trunk Actuator Lock-image-3520056203.jpg
Trunk Actuator Lock-image-3818225869.jpg   Trunk Actuator Lock-image-4217254526.jpg   Trunk Actuator Lock-image-2382905442.jpg   Trunk Actuator Lock-image-4034802406.jpg   Trunk Actuator Lock-image-938243753.jpg
Trunk Actuator Lock-image-2265904892.jpg   Trunk Actuator Lock-image-292897011.jpg   Trunk Actuator Lock-image-3616857833.jpg
The following 4 users liked this post by magmedia:
edobernig (10-25-2014), lcmjaguar (11-15-2014), ragman1171 (10-09-2014), tampuhaw (10-20-2019)
Old 10-09-2014, 04:24 PM
magmedia's Avatar
1. Remove the plastic latch surround by removing the two plastic clips.
2. Remove two torx bolts holding latch in place.
3. Remove plastic hand grabs and a couple plastic clips. This will allow the trunk lid cover to be moved enough for access.
4. Disconnect the emergency trunk release.
5. Disconnect the lock release cable "arm"- there is a small rotating clip on the end of the cable.
6. Release the grey connector. It is the "squeeze" type.
7. Reverse sequence.
Bought the component from Gaudin Las Vegas on eBay. This was a 2 day delivery, even with their base shipping option.
Enjoy!
-mag
The following 5 users liked this post by magmedia:
Dan.B (06-14-2019), DanJensen (11-11-2014), JagJasper (09-23-2023), lcmjaguar (11-15-2014), ragman1171 (10-09-2014)
Old 10-24-2014, 09:28 AM
Iggysun's Avatar
Megmedia thanks you for the helpful input. I will be taking the lock out and checking the switch next week and will let you know how this went. 10-24-14
Old 11-11-2014, 12:08 PM
DanJensen's Avatar
Mag:
Thanks for the pictures and instructions.
I'm curious as to why you changed out the latch. In my case, the trunk will mysteriously open on its own and set off the alarm. This occurs randomly, and now more frequently, when the trunk is heated during the day by the sun. Otherwise, the latch works without issue. I assume that one of the microswitches in the latch is going bad. The latch was replaced at 52K miles under warranty, but my sense from reading posts on the forum is that this is a not-uncommon failure. I suspect I'll have to spring for a new latch.
Dan
Old 11-11-2014, 06:35 PM
magmedia's Avatar
Originally Posted by DanJensen
Mag: Thanks for the pictures and instructions. I'm curious as to why you changed out the latch. In my case, the trunk will mysteriously open on its own and set off the alarm. This occurs randomly, and now more frequently, when the trunk is heated during the day by the sun. Otherwise, the latch works without issue. I assume that one of the microswitches in the latch is going bad. The latch was replaced at 52K miles under warranty, but my sense from reading posts on the forum is that this is a not-uncommon failure. I suspect I'll have to spring for a new latch. Dan
When selecting trunk open button, release motor would run and not release.
When closing trunk it would require 3 slams to latch (with no help from electric closer). Worked perfectly after replacement.
This was on 2004 VDP in radiance red, no trouble with the 05 super v8.
-mag
Old 11-13-2014, 07:55 PM
esloser's Avatar
Where did you order or trunk actuator from? My 2004 xj8 is exhibiting the same problem - especially after sitting for a couple of days. It won't release when pushing the button even though the motor runs.
Old 11-14-2014, 03:23 PM
DanJensen's Avatar
To my knowledge, this is a dealer or Jaguar-supplier item only. There are no generics that I have read about.
Old 11-15-2014, 09:03 PM
magmedia's Avatar
Mag
Old 02-05-2015, 01:27 PM
haswell4's Avatar
thank you to all who replied so quickly, i have now ordered the lock actuator from a jaguar parts dealer at 146GBP.. good job she's worth it heh?
regards
John...
Old 02-09-2015, 03:43 PM
DanJensen's Avatar
John:
I hope this solves your problem. I have not been so fortunate to date. My alarm goes off randomly, but only when the sun is shining on the car. It never goes off at night or on cloudy days. Most of the time the trunk unlatches as well, but not always. I mistakenly assumed sunshine = heating = faulty microswitch in trunk unlatch = trunk unlatch = alarm with door unlock. Unfortuantely, installing a new trunk latch made no difference. I still get random alarms when parked in the sun. To make things even more puzzling, I opened the left rear door once and the trunk unlocked! BTW, in looking very closely at the trunk latch, I could see no way to gain access to the microswitches for a DIY repair.
The issues with my car may be unique, based on what I have been able to glean from the forum. By way of background, the car spent several weeks at the dealer a few years ago as they, the West Coast rep, the US rep, and a factory rep tried to figure out why the alarm system would not arm. After reflashing the front and rear ECMs plus other undocumented changes, they solved the problem, although the mirrors didn't and still won't auto fold, another problem they tried to resolve.
Dan
Old 02-10-2015, 07:57 AM
haswell4's Avatar
John:
Dan
Hi Guys .. new actuator arrived and fitted,
now everything is working perfectly including central locking ...
when i first got my car the mirrors didn't auto fold but i moved them foreword by hand and there is a tray type thing that slides out and it was full of crud so after cleaning and generous application of wd40 "viola they work"....
so thanks again Guys for the quick replies..
kindest regards...John...
aholbro1
08-05-2021 05:02 AM
XJsc-guy
11-23-2015 01:56 PM
blh-1952
09-28-2015 07:07 AM
findre
09-10-2015 05:46 PM
speacock
09-10-2015 12:14 AM
Quick Reply: Trunk Actuator Lock
