What the heck it that ticking???
Old 12-21-2013, 11:52 AM
Drb007's Avatar
Default What the heck it that ticking???
Over the last week or so I have noticed a ticking sound when my 04 XJR is running. It sounded like a top end noise like a lifter when the oil is low or thin, but it is not related to engine rpm. I repeat, it is NOT related to engine rpm! It is loud enough that a passenger would say, "what it that ticking sound?"
If I an in park and gently increase the rpm, the noise does not change, but if I bring it up to 3000 rpm and take my foot off the throttle, it might stop for a few seconds, then start again. Its driving me a bit nuts...ideas?
Old 12-21-2013, 12:30 PM
Fraser Mitchell's Avatar
Received 2,455 Likes on 1,951 Posts
You need the mechanic's stethoscope, i.e. a long shank screwdriver placed on a likely spot of noise then listen at the blunt (handle) end. YOu should soon find it.
FWIW, (and only my opinion !), it could be the variable valve timing device on one or other of the cylinder banks.
Old 12-21-2013, 08:09 PM
Drb007's Avatar
Two things:
1. I am pretty sure the XJR doesn't use variable valve timing.
2. It is not related to engine RPM.
Old 12-22-2013, 04:47 AM
I am running out of ideas, but the fuel vapour purge valve might be clicking away to purge the vapour canister. However this should stop when it's finished. Also try turning off the air con and see what happens. That is not revs dependent unless the compressor is whining. There are a couple of valves in the aircon assembly.
Old 12-22-2013, 04:45 PM
rosskuhns's Avatar
does it go away ever? it does sound like the evap purge valve
here's a thread:
https://www.jaguarforums.com/forum/x...icktick-90401/
Old 12-22-2013, 10:16 PM
Drb007's Avatar
Thanks guys! I read the link and believe that to be the noise...purge valve!
Old 12-23-2013, 11:47 AM
rosskuhns's Avatar
yes, i've got the same thing and thought it was a sticking lifter, I was not happy until i searched this out.
Old 12-23-2013, 01:32 PM
SaturnV's Avatar
Once you realize it's not a motor issue, it becomes easier to ignore. We don't notice it anymore.
Old 12-24-2013, 09:02 AM
rosskuhns's Avatar
I found this how to video, very good; and xk8, but it should apply.
there is another video he did in the list to the right showing how to remove the fender liner.
*you can also see the foam 'sleeve' that jag put on the xk8, starting in 2006 I believe, to try to quiet the valve down.
anindyam (01-02-2014)
philwarner
43
09-10-2023 11:30 AM
philwarner
01-31-2016 09:36 AM
jospolice
10-02-2015 07:16 PM
willemh
09-28-2015 06:22 AM
Quick Reply: What the heck it that ticking???
