XJ8 Rear Seat Removal
Old 06-28-2009, 02:27 PM
mitch.thompson's Avatar
Default XJ8 Rear Seat Removal
It's me again (Margaret).
Just noticed that the latch for the middle seat belt in the back seat is fallen beneath the rear seat. I tried the "push back-lift up" method common for most U.S. cars, but it didn't work.
I've done Google searches, and searched the archives of several Jaguar forums, but couldn't find how to remove the rear (bench) seat cushion in a 2004 XJ8. Please help.
Thanks in advance,
Mitch
Top Answer
01-23-2013, 07:15 PM
Jag XJ8 Red's Avatar
Jag XJ8 Red
Jag XJ8 Red is offline
Banned
Here ya go! Helps to have little fingers.
Attached Thumbnails XJ8 Rear Seat Removal-image_zps1b370d52.jpg   XJ8 Rear Seat Removal-image_zps7084fb8a.jpg
Old 07-01-2009, 11:45 PM
MarlboroLTS's Avatar
I don't know if we are the same, but I have an '06 XJR....feel around the lower front edge for some plastic triangler shaped "fingers". If you find them, try to move them either left or right. They are latch releases (4 of them). If they won't move, put a little downward pressure on the seat at the same point as the latch. Once you have released all 4 latches, lift the front of the seat up to unhook the rear. Be mindful of any wiring for heated seats or whatever. Hope this helps Bro.
danveenstra (09-01-2014)
Old 07-08-2009, 05:47 AM
Thank you MarlboroLTS, they are indeed the same. The seat came up with no problems, I was able to recover the seatbelt latch, and netted $1.74 in change in the process ;^). Good for a gallon of Premium gasoline, anyway...
Old 02-15-2011, 07:18 PM
magmedia's Avatar
Default Rear seat removal - 2005 XJ8L
Anyone else successful in removing the rear seat on an 2005 XJ8L?
I have re-read the above and retried to remove the back seat but am unable to move the 'fingers' left or right. Am I missing another bit of info?
EDIT: So, should I be feeling for the levers/latches through the leather or reaching behind and up the seat foam to find the release?
Thanks-
Old 02-15-2011, 08:27 PM
user 2029223's Avatar
Banned
It is in fact damn difficult on some cars. The key is downward pressure on the seat as you pull the latches down. I had to get the dealer tech to walk me thru it the first time but it is still a 2 man job for me.
bondman07052 (01-23-2013)
Old 02-16-2011, 11:03 AM
magmedia's Avatar
Tarheal-
Thanks for the response. I will enlist a second set of hands and give it another go.
To clarify, am I reaching under/behind the foam edge of the seat, or should these release latches be able to be reached and moved through the leather on the 'face' of the seat?
Old 02-16-2011, 11:23 AM
Drew's Avatar
They are under the seat of the edge that faces the front of the car, by your feet.
Old 01-23-2013, 06:42 PM
bondman07052's Avatar
I am in the same boat. i bought a 2008 XJ8L and am missing the middle seat belt attachment. I have playd with taht seat for an hor and cant get the middle to release !
RRGGG !
Old 01-23-2013, 06:43 PM
thanks for the info on how to do it- I will have my 7 year old sit on it while I try and release it again,
Old 01-23-2013, 07:15 PM
Banned
Attached Thumbnails Click image for larger version
ID:	31097   Click image for larger version
The following 16 users liked this post by Jag XJ8 Red:
blindboy (11-17-2016), bondman07052 (01-24-2013), Coopster (09-09-2014), danveenstra (09-01-2014), H20boy (06-06-2014), jackra_1 (02-27-2015), jerry_hoback (04-25-2021), lcmjaguar (06-07-2014), Lou in Dallas (09-11-2014), magmedia (01-24-2013), mhamilton (04-11-2013), paydase (01-03-2017), scooterforever (01-04-2022), slmskrs (09-02-2017), waynepaulj (09-09-2014), XK8+XJ8L (04-12-2014) and 11 others liked this post. (Show less...)
Old 01-24-2013, 07:27 AM
thanks- that was so nice of you to post that.
Old 06-06-2014, 11:49 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Jag XJ8...photos were a HUGE help with my rear seat back disassembly. If I could have given you 10 more thank-you clicks, I surely would have. There is no way I would have gotten my seat bottom removed without knowing what I was looking for and where.
Old 06-07-2014, 08:44 AM
gmcgann's Avatar
Hey, what strikes me is that in the original post from 2009 $1.74 was enough for a gallon of premium!
The following 2 users liked this post by gmcgann:
Eric-in-Texas (02-20-2022), Naso--Lituratus (04-07-2015)
Old 09-02-2017, 03:40 PM
slmskrs's Avatar
Location: San Francisco Bay Area (south bay), California USA
Great pictures. Gave me an idea of what I was feeling around for. I made this quick video to show how to press the latches to release the seat. I could find them, but about broke a finger trying to push them the wrong way. Once you know which way they go, it is a piece of cake to remove the bottom cushion. I only had one (far right one) that I had to push down a little on the seat cushion while pressing the lever (fingers didn't like that). But I had the seat out in under a minute. I suggest putting a screwdriver or something next to each latch when you release it so that the seat doesn't pop back into the latch while you're working on the next one.
The following 8 users liked this post by slmskrs:
2004.X350.XJ6.Austria (09-18-2017), Dan R (09-25-2017), Eric-in-Texas (02-20-2022), genec (09-24-2017), jerry_hoback (04-25-2021), junkyarddog (12-21-2023), StagByTriumph (05-02-2024), woox4 (09-02-2017) and 3 others liked this post. (Show less...)
Old 09-18-2017, 05:37 AM
2004.X350.XJ6.Austria's Avatar
Wow, thank you! Only your video really clinched it. I did it in 15 minutes. Thanks!
Old 09-24-2017, 06:17 PM
genec's Avatar
Thumbs up
I agree. This was very helpful. Sometimes something that seems obvious to someone isn't obvious to everyone.
If a picture is worth a thousand ...then a video is worth a million "attaboys" .
Thanks again!
Old 09-24-2017, 06:34 PM
Received 1,423 Likes on 1,066 Posts
And if you need to remove the rear bench just pull the two cloth pulls hanging under the base of the rear bench. They look like seat belts minus the latches but you pull each then pull the bench out.
Took me a while to figure out on a 2005 VP breaker vehicle.
motorcarman (12-17-2021)
Old 12-13-2021, 06:15 AM
Nautivan's Avatar
Default Rear bucket seat removal 2006 Xj350 super v8 Portfolio
Anyone have tips on how to remove the rear bucket seat bottoms? Am I feeling for the same triangular levers as in a bench seat? Makes sense that the hardware on body is the same regardless of seat fitment. None of seat controls on side - recline, headrest and lumbar - are operational thus I’m assuming it must be switch. The memory buttons on the door will move the seat ever so slightly. The seat switches on the other side are fully functioning. Can the seat switch be removed without removing the seat bottom?
Old 12-13-2021, 09:06 AM
roviw's Avatar
When my electric rear seat on one side was not working when i first bought my 2004 Super v8 i also thought it may be a switch, however it was sorted by the dealer doing a software update ! no need to renew the switch after all.
Sometime electronics in cars can be like a computer, turn it off and on again, I dont know whether a hard reset ( disconnect battery for a while and the reconnect ), may help you.
Old 12-13-2021, 09:26 AM
Nautivan's Avatar
Default Unintended consequences of hard Re-set
Thank you Roviw. Are there potential untintended consequences from a “hard Re-set?” In other words, is there any known reason I should be reluctant to try this?
Quick Reply: XJ8 Rear Seat Removal
