XJR 2004 remove front door panel
Old 03-08-2011, 04:41 PM
xjr2004's Avatar
Smile XJR 2004 remove front door panel
sorry for my bad english
I can find anywhere on the Internet ..
I would like to remove my front door panel can someone help me please?
Old 03-09-2011, 07:33 AM
oldmots's Avatar
Rmove the nylon phillips screw and push grommet in the bottom of the door
remove the 2 covers on the screws in the black front edge of the panel and remove the torx screws
Remove the small cover and torx screw in the door handle recess
Remove the 2 phillips screws under the armrest
Lever off the center part of the panel with the door handle on it but not including the black trim edge that it sits on top of. This black edge is the exposed portion of the weathershield panel underneath. You cannot get it off yet so do not pry under it. Disconnect the electrical connectors. Don't drop it until the connectors are loose. Careful not to damage the speaker.
With the door handle portion of the panel off, you expose the inner weather panel of black plastic. It has a bunch of large head torx screws in it. Remove these and pull the panel off. I just lay this panel down still connected to the wiring but you can remove the wiring and take the panel away.
xjr2004 (03-09-2011)
Old 03-09-2011, 07:35 AM
oldmots's Avatar
OOPs, I always forget a step! Remove the door handle cable from the lock button which is in the first panel you remove, it just detaches by hand but be careful, the whole thing is plastic and will break.
Old 03-09-2011, 10:21 AM
xjr2004's Avatar
Default Little help extra please?
Hello Oldmods,
Thank you for your help!
But we still stick to a problem, about the door panel.
The problem is, we thought that the veneer strip in the door panel had to be removed, of course without cusses.
Now, we understand that we only have to remove the panel itself not the strip.
So can you help us with further detail about where to pry the panel loose?
All the screws have been removed and the panel is loose, but we cant get it off!
Please help?
With kind regards we're waiting for an answer!
Old 03-09-2011, 10:33 AM
oldmots's Avatar
The outer panel is held by pressure studs and must be pried away from the inner weather panel. I used a special plastic pry bar made for interior panels. I never looked to see how the veneer is fastened, but it is a part of the outer panel and comes off with it.
Old 03-09-2011, 11:10 AM
xjr2004's Avatar
Default We will chack this tonight!
Hello again Oldmots,
We'll try this tonight and will let you know, if it worked!
Maybe we'll shoot some pictures of the scene, when it worked out.
We'll let you know!
Thank you for so far with kind regards!
Old 03-09-2011, 01:16 PM
xjr2004's Avatar
Default Please more details? :icon_patriot:
Hello Oldmots,
Back Again without succes!
(Lever off the center part of the panel with the door handle on it but not including the black trim edge that it sits on top of.)
Do you mean that we have to remove the whole panel?
The panel is very stuck and we thought that the bucket where the door handle is positioned needed to be removed at first.
But this cant because the bucket is positioned at the back of the panel.
So first the panel needs to be removed, right?
And about removing the door panel, where are those pressure studs placed where you talked about?
(black trim edge that it sits on top of)
What does this mean, what is this, a rubber or the chrome edge from the bucket?
Maybe you can send me some pictures with the describing of the positions from the pressure studs etc......
Otherwise lets communicate by email: w.rijks@zuka.nl
Thank you very much an with kind regard from Hollland
Old 03-09-2011, 02:35 PM
xjr2004's Avatar
Default Finish!
We don't know what did go wrong, but we were to careful.
You have to pull very hard at the armrest to pull of the panel.
But in the end it all became to a succes with the help from you!
Now let's repair the
Thank you for the help and advice.
We shall make pictures and upload them to this tread.
With kind regards,
Bas and Wesley from Holland
Old 03-10-2011, 09:04 AM
oldmots's Avatar
Congratulations.....trying to describe a procedure in words is difficult, you interpreted it well. I always have trouble uploading pics, so I go with the words.
philwarner
12-06-2021 07:13 AM
Doberman_Fan
22
12-24-2019 06:21 AM
10 XF Premium
09-18-2015 10:03 PM
Noelmid
09-02-2015 03:13 AM
jagent
08-30-2015 08:42 AM
Quick Reply: XJR 2004 remove front door panel
