1997 xj6. No crank, shifter won't move out of park
Hello there, new to the forum. Hope this is posted correctly. I have a 1997 xj6 that I tried to jump start because the battery was dead. Even tried another battery. Seems to be plenty of juice but when I attempt to start it, the car does not crank. Also I would think that if the key is in the run position, I would be able to shift the car into neutral. The shifter will not move out of park. The cast is st my vacation property and I had very little things to diagnose it and will return there this weekend. Just hoping someone had a similar experience. Thanks in advance for any reply
