2004 xjr air suspension down
Hi, New to the forum, need some advice, driving the other day, in the rain, air suspension fault showed up, front end dropped. Drove the car home, did some checking, no leaks,switched out relay, nothing.
Compressor does not come on, although if you jump the pins on the relay it runs and delivers pressure to the solinoid valve, but does not distribute to any lines.
Checked as much as I can, gathering info from your previous posts, need some help.
CAr has 93,000 miles on it and has been perfect up to this point. HHHeeelp
mhamilton
07-29-2016 12:22 PM
