2005 Jaguar XJ8 Reduced performance and erratic shifting
Received 2,679 Likes
@Fbalcazar, two things to check before going any further with a diagnosis:
- Battery voltage across the terminals when checked with a voltmeter. There should be a minimum of 12.6 volts available for all modules to communicate along the CAN-BUS.
- Fluid level in the gearbox. If it hasn't been serviced, it should have a fluid change and pan/filter replacement every 100,000 km/62,000 miles or five years.
