2011 XJ Vanishing TFT Display
Another problem I haven't seen posted yet, that may be unique to me (I must have the worst XJ they made). This one is the vanished TFT display. Where your entire dash disply (speedometer, etc.) just vanish. It will come back usually within 15-20 seconds. It can happen anytime, but mostly happens when exiting a dark parking garage into daylight, going under tunnels/overpasses, etc. It has not happened very often (thankfully), but the first time it happens it will freak you out, and second time and thereafter it just pisses you off.
Spoke to Jaguar NA a few weeks back, they said they had only one other known instance of this happening, so I guess I'm not alone. And it appears another "software update" resolves this, which hopefully will be addressed next week.
Again, no one else is experiencing this?
Definitely not a display brightness setting issue. Disply brightness is set at highest, and you can see the disply when the lights are on, and you are in a garage...the moment you exit the garage into daylight, the disply slowly starts to vanish. Then will slowly start to reappare about 15 seconds later. Most of the time it happended in situations like this, though once in broad daylight. I've been told the the unit needs to be replaced (which means not taking it out, but replacing with..again, some sort of software component).
I can live with it for the moment as it doesn't happen too often, and hopefully they just fix it for good.
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Perhaps, though I fail to see how any such settings, by design, would cause the entire disply to vanish, so definitively a defect. They told me today it was fixed, but cannot pick up car yet as they need more time to fix other things. Will be 3rd day they've had it this time. Last time was 4 days.
Hi Pwl.
You are what we in the IT industry call an "early adopter", so it is your fortune to be first with the new stuff nobody else has got, but your misfortune to be the first to find out about problems the car developers and testers did not find out about whilst testing, OR they did find out but were ignored as the launch date was set in stone.
I have to say an electronic instrument display always makes me a bit nervous. There was one fitted to a Lagonda in the 70s and this used CRTs !! The original Jaguar XJ40 had something similar. Incidentally, with its leading-edge fault detection and warning system, the early XJ40s were said to be the car that always told you there was something wrong with the car every time you started the engine. Not good for customer relations !!
I had a similar issue happen today. This was the second such incidence where my entire dash flashed then went completely black. On both occasions, the display blinked then reappeared after about 20 seconds.
Maybe it's just some visual effects to go along with the rattles and pops.
Cheers,
I posted of having this issue back in January... along with 100 other issues that are wrong with my vehicle, still, that Jaguar NA knows about and has refused to replace my car. I still have the issue, however, mine will stay off longer than that. What are the last 4-5 #'s in your VIN? Cars pre-2000 vins are plagued with issues unfortunately.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
vacolorito
09-25-2015 09:29 AM
