XJ ( X351 ) 2009 - 2019
2011 XJ window wont go up or down - RESOLVED
Old 01-06-2022 | 08:59 AM
Pedro soto's Avatar
Default 2011 XJ window wont go up or down - RESOLVED
Hello all,
I just purchased a 2011 XJ with 60k miles, I love the car.
My rear passenger window wont go up or down, when I press the button I can hear a click but no movement at all.
Any suggestions will be appreciated.
Thanks in advance.
Pedro
Last edited by GGG; 01-31-2022 at 06:43 AM. Reason: Add 'RESOLVED' to thread title
Old 01-06-2022 | 02:02 PM
RedSky's Avatar
Do you hear the click coming from the door area? If so, and there is no movement of the glass, you might try removing the door card
and seeing if the regulator is stuck/jammed. it's not unheard of.
Old 01-06-2022 | 03:27 PM
Thermo's Avatar
Pedro, keep in mind that these windows have a safety feature in them that prevents the window from operating if it senses something providing resistance to the window. It figures this out by watching the current in the motor that raises/lowers the window. If you have binding there, the current can get high enough that the car thinks a hand is affecting the window. Also, when a window motor starts to go, it will loose its ability to develop torque, which is what is needed to raise/lower a window. So, if the click you are hearing is coming from the door in question, like was said, you either have a window regulator that is stuck or the motor is starting to go and you will need a new motor.
Old 01-07-2022 | 03:42 AM
Originally Posted by RedSky
..... If so, and there is no movement of the glass, you might try removing the door card and seeing if the regulator is stuck/jammed. .....
Originally Posted by Thermo
..... these windows have a safety feature in them that prevents the window from operating if it senses something providing resistance to the window. ......
+1
Do some careful reading before attempting to remove the door card. Fixing screws are never obvious and it's easy to break plastic clips.
Old 01-07-2022 | 03:19 PM
Pedro soto's Avatar
I did heard a click next to the door handle.
Old 01-08-2022 | 04:48 AM
Pedro,
You don't have sufficient posts to be able to download attachments from the forum so I've sent the attached PDF to the email address you have registered with the forum. It's an extract from the Workshop Manual with the procedure for removing the rear door trim.
File Type: pdf
kroache (01-08-2022)
Old 01-08-2022 | 05:22 AM
Pedro soto's Avatar
Originally Posted by GGG
Pedro,
Thank You, Sir.
GGG (01-08-2022)
Old 01-29-2022 | 02:22 PM
Pedro soto's Avatar
Pedro,
Thank You for the step by step instructions, I contacted a local shop and they quoted me $400 installed. I went ahead and purchased a new door motor with a regulator attached, after reading your tips and others here I was able to do the job myself. It cost me $100 for parts and a little elbow grease. Finally the window works as intended.
Please keep up the excellent work on this site, you are saving people lots of money.
Pedro
The following 2 users liked this post by Pedro soto:
GGG (01-31-2022), kroache (01-30-2022)
Old 01-31-2022 | 06:42 AM
Originally Posted by Pedro soto
..... I was able to do the job myself. It cost me $100 for parts and a little elbow grease. Finally the window works as intended. .....
Pedro,
Good to hear you resolved the issue and did the work yourself.
Pedro soto (01-31-2022)
Old 02-05-2022 | 06:26 AM
Pedro soto's Avatar
Default Sun Visors needed
Pedro,
It seems like sun visors are a problem with jaguar. Any idea where I can find a driver side sun visor replacements, without paying hundreds of dollars for a grease covered one?
Most people selling them think they have gold covered visors. Lol
Pedro
Old 02-05-2022 | 11:28 AM
clubairth1's Avatar
Even better that you reported back what the fix was!
Good luck with the visor. I never have been able to recover them without it looking terrible. Used was no better. I finally just gritted my teeth and purchased 2 new ones for my old STR. Really improved the interior but they are VERY expensive new!
Pedro soto (02-05-2022)
Old 02-05-2022 | 12:56 PM
Stuart S's Avatar
I had the same problem a few years ago. I removed my driver's side sun visor and separated the two halves to look inside and see if it was repairable. Unfortunately, the molded plastic was in too many little pieces.
In the US, Jaguar had 2 replacement visors in various colors. The first, and most expensive, included the required NHTSA warning labels bonded to the visor. The second did not include those labels. I don't know what's available now.
COVID has affected parts availability.
Old 02-06-2022 | 09:44 AM
clubairth1's Avatar
Thanks Stuart I did not know that and funny enough when I did replace my sun visors I used adhesive remover and took all the warning decals off the new visors. I think they look much better that way.
Yes I have taken at least 6 different ones apart to find the secret but no luck. I even paid $150 to get one visor redone but the outcome was terrible and I just could not install it on my car!
Old 02-06-2022 | 12:14 PM
2018XF25T's Avatar
Old 02-06-2022 | 01:47 PM
Stuart S's Avatar
Originally Posted by 2018XF25T
Would this be a better alternative to the sun visor problem? ...
Probably not. That Amazon device attaches to the existing sun visor, which is broken. The broken sun visor doesn't stay in place when moved up or down or left and right.
If the existing sun visor is removed, how do you install that Amazon visor so you can move it around? Also, it's translucent and won't completely block the sun.
Old 02-08-2022 | 05:35 AM
2018XF25T's Avatar
Hi Stuart
How about this one? Perhaps it might work on your part, it is not an XJ but it might give you an idea how to fix the sun visor to stay up in place
The following 2 users liked this post by 2018XF25T:
kroache (02-08-2022), XJsss (02-08-2022)
Old 02-09-2022 | 08:19 AM
Stuart S's Avatar
Hi Stuart
https://www.youtube.com/watch?v=_8jcoSgdjO4
That's a clever fix, but it's a moot point. I no longer have that broken visor because I replaced it with a new one.
Also, that fix won't work because the visors on my 2013 XJ don't slide on the shaft. All they do is rotate up and down. That's just another thing that the factory forgot. I don't know if that changed in later models.
Old 02-12-2022 | 03:21 AM
Kalepsis's Avatar
Pedro
Where did you get the parts? Both of my passenger side windows have an issue with the hall sensors (or regulator binding) and they take three attempts to roll up. My local shop quoted me $400 for just the regulators, and another $350 for labor. On each door.
I don't like people who think I'm a chump, like the Jaguar dealer in Hilton Head that told me it costs $212 to replace the engine air filters, a job that cost me $8 and ten minutes to do.
Old 02-12-2022 | 12:03 PM
clubairth1's Avatar
What I do is find the correct part numbers first. All the on-line parts dealers have good documentation and be aware that Jaguar does everything according to the last 6 digits of your VIN. So have your VIN handy when looking for parts. This should tell you if that part number will fit your car.
Jaguar is the best place to get parts but be sure and do some searching on EBay too. After you find the correct part number.
If your serious consider getting and installing JEPC as we now have a member who built a viewer so we can use JEPC. JEPC stopped working because of the ending of Flash and the removal of flash from just about everyone's machines because of a MS software update. Once it's gone you can't get it back.
But with Jpart installed now JEPC works fine. JEPC = Jaguar Electronic Parts Catalog.
Jpart and JEPC are both free so it just takes a bit of work on your part to install and get them operating.
Search for Jpart and JEPC to find the free software.
And another public thank you to the guy who wrote Jpart!!! JEPC was a mess before that came out.
Old 02-12-2022 | 03:35 PM
Kalepsis's Avatar
Thanks, I found the part numbers I need based on my VIN (C2D31415 for the front, C2D36914 for the rear) but I'm still having trouble with finding affordable parts, hence my original question: where can these regulators be found for $100? The lowest price I can find anywhere is $338.
Quick Reply: 2011 XJ window wont go up or down - RESOLVED
