2011 XJL; driver seat won't move at all...
This is great resource here, have been reading for a long time, but haven't seen any posts on this particular problem.
I've got a 2011 XJL with about 70K miles. So far, have had zero problems with it, and happy as can be with the car. Curiously, the driver's side seat suddenly, and without warning, will not allow any adjustments whatsoever. This is true of all of the 11 or so adjustment modes. The memory buttons on the door also have no impact at all. The driver's side mirror can be adjusted by it's motor, but the memory buttons will not move it back to it's stored location.
I've seen some posts kinda like this about earlier models, but nothing specifically for the newest ones. Does anyone have any insight on this problem??
Thanks in advance for your help!
John
John
jcwellsq8, in the engine bay fuse box, check fuses F42 and F46 (both 30 amp fuses). Then in the rear fuse box, check out fuse F19 (10 amp). Any of these being blown can cause the computer for the driver's seat to not function properly. if this does not fix things, then let me know and we can take things from there.
jcwellsq8 (08-17-2018)
Is the next step to have the dealer hook it up to diagnostics?
jagmom123
03-02-2021 06:58 AM
RC Tod
06-27-2018 08:55 AM
