2011 XJL
Welcome to the forums QueenB369,
Jaguar rarely waste time or money redesigning something. When I checked the X351 Workshop Manual (relevant extract below), it is identical to the design used on my XK!
The only tricky bit is putting the harness in the service position. Make sure it engages correctly on the bracket or you'll be removing the door card to get it back.
This photo of the door handle on my XK is clearer than the X351 Workshop Manual graphic:
The blue harness connector is released to remove the handle. The black plastic trim at the rear is just clipped into the door panel.
Thank you Graham!!
The diagram is so tiny, but helpful. It looks like i need a 4 Nm tool to remove the screw?
Also, I'm not good with car lingo, what does this mean:
"The only tricky bit is putting the harness in the service position. Make sure it engages correctly on the bracket or you'll be removing the door card to get it back."
I appreciate your help!
QueenB369 (04-13-2022)
You can feel it click into place rather than hear it.
