2011 XJL - Scrapes going into garage
Other than moving I'm not sure there is much you can do. The bottom of the xj is all covered in plastic covers and is most likely what is rubbing. There must be a lot of cars with this problem in your complex because the xj is not a particullary low riding car maybe you can talk with the management to have them correct the steep angle. Good luck.
Received 2,193 Likes
Thx. Yes, Brutal is right about going in slow at an angle. That works. Coming out is the problem. Since, its a condo complex coming out in reverse is an issue because you can't really see well and could hit someone.
I'm beginning to think because of the long wheel base on the XJL the car is scraping.
