2011 XJL Supercharged badgins
1 Post
You have to remove the front wheel liner, and then there is an 11mm (might be 10mm or 12mm?) nut which attaches to the bolt which is an integral part of the side vents, I actually have a spare one of these that says “Supercharged’ if anyone one needs a spare…I have a 2014 XJR and those are different…it is interesting actually that that same part number has 8 different side vents options that fall under the very same part number, so don’t rely on the part number alone if you ever need one.
