2012 - 2013 emergency key
I'm not sure if the 2012-2013 keys are different from the 2011 ones, but there is a small button on the side of the key which releases the latch and opens up the clamshell of the keyfob
Randy, just slide the cap on the side of the new key forward (away from the attachment ring) and it comes right off, exposing the emergency key and battery tray.
LiquidIce (12-12-2012)
I have a 2012 xjl. I have the large heavy key! I prefer it to the lighter key which comes with the xf loaners I've driven. They feel very cheap. My car was built on 11/11 but it is a 2012 model. So I'm not sure when they switched to lighter key on 2012? I think maybe its only on the 2013 models.
Thanks Diablo for the explanation. Btw, speaking of the emergency key, has anybody had their battery go off on them and have had to use the convoluted way to open the driver door, then the bonnet, and finally the trunk/boot? I'm a computer software guy and even I get shudders just thinking about all that I would have to do if my battery ever dies on me, haha!
So I had to open the door w/ the emergency key, charge the battery enough via the hood pins to turn the center display on, disable valet mode, open the trunk and *then* charge the battery - all without instructions because my manual was in the trunk! What a PITA that was to figure out
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Yes, I had this happen to me after I only had the car for 2 days so I didn't know the procedure at the time. I had dropped off the car to get the windows tinted and had enabled valet mode also. The tint shop had the doors open all day and ran down the battery in the process, then managed to close the doors while they were locked.
So I had to open the door w/ the emergency key, charge the battery enough via the hood pins to turn the center display on, disable valet mode, open the trunk and *then* charge the battery - all without instructions because my manual was in the trunk! What a PITA that was to figure out![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
![Icon Rolleyes](https://www.jaguarforums.com/forum/images/smilies/icon_rolleyes.gif)
![Icon Warped](https://www.jaguarforums.com/forum/images/smilies/icon_warped.gif)
![Icon Errrr](https://www.jaguarforums.com/forum/images/smilies/icon_errrr.gif)
I'm seriously entertaining the idea of jerry-rigging a cable from the Luggage Compartment Emergency Release Handle to the interior of the car just to avoid the headache you went through.
Get_Jaggy_With_It
09-25-2015 03:09 PM
