2012 Jaguar XJL Portfolio Problems??
The key FOB and the transponder in the key are two separate systems. The battery runs the FOB and transponder is responsible for starting the car. You can prove this to yourself by removing the battery completely and starting the car using the push button.
So first thing is put a new battery in the FOB/Smart Key. But they also wear out and are not very expensive off of EBay. So you might consider getting a new one.
Do you have 2 keys? Seems like all used cars always come with just one key. Be sure and get that second key BEFORE you have problems. It's much easier to add a key now.
But your problems are pretty minor and should be easy to fix. Keep posting back for more help.
JordanXJL (08-29-2021)
Fraser Mitchell, thank you for your response! I will stay on top of maintenance, and will keep an eye out for all known/common issues on the XJ's constantly. And that's quite the Drive! England to Germany roundtrip! Glad to hear you never had any worries or issues on these trips, makes me feel rest assured!
... 2) Key fob does not work, I can't lock or unlock the car with my fob but car starts by push start so the battery is not the issue i'd assume. 3) One of the cupholder slide covers came apart as I opened my cup holder. Kind of frustrating as the dealership literally showed me it worked fine during my virtual tour of the car. ...
Don't try to bend the prongs, as they are fragile and if they break you'll need to buy a new Smartkey and have it programmed to the car.
You can easily fix it with a small piece of aluminum foil. Fold it into a shim and wedge it under the CR2032 battery to make a tighter fit against the prongs.
I, too, used Superglue to repair the sliding doors over my cupholders, but it didn't like how it turned out because ther sections kept coming loose and falling off. When I found that the cupholder assembly was updated with a new, improved design I decided to replace it. Here's how I did it, with detailed instructions and photos.
https://www.jaguarforums.com/forum/x...olders-208542/
I'm not a car mechanic, and if I can do it, so can you.
Clubairth: As you guessed, I do have one key. I didn't know the FOB and transponder were two separate systems, this makes more sense now. I will get a new one this week, to ensure I don't have problems. I am definitely happy as all these issues are minor, just very inconvenient lol.
Fraser Mitchell: That's awesome! I'd love to visit such destinations. Safe travels on any future trips!
Stuart: Very good information, I plan to get a new Key for backup but if I can get the first working with aluminum foil, then I'll happily be able to say I have two keys! LoL.
I just checked out your thread on the sliding cupholders. Seems quite easy and intuitive. Huge thanks for the response!
Dang...just got home from taking the car out on my third drive. Went 30mi. to go visit my Mom as tomorrow is her birthday. When I started the car to go home, I got a notification "service required" which as I noted before and will again: I expected to have to do maintenance to the car, however it was just "serviced" less than a month ago? As I get home and am on the roads leading up to my home and am backing into my garage the wheel is shaking very noticeably at low speeds in both drive and reverse. Not too sure what this could be as both alignment and brakes are OK... ![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Clubairth: back to what you were saying previously...I got this from one of the owners who like to let multiple problems pile up until the car is a mess! Big bummer and I am quite disappointed that this dealership would sell me a car in such condition. BUT, I will sort through EVERY one of these issues and get the car to it's fullest potential.
Shortly after the 2012 model, Jaguar changed the key fob to one much smaller and lighter. That would be the one I'd recommend as a replacement. You can also change only the shell of your existing fob. You might be able to improve the battery contacts at the same time.
https://www.jaguarforums.com/forum/x...2012-a-239831/
JordanXJL (08-30-2021)
#28
If the car had the oil changed at the dealer he should have reset the service reminder. Can you call him to do that?
It's a bit annoying to have the service indicator coming on at every start. Usually it has a mileage associated with it that counts down as you drive.
Good advice about the scanner and I have a very cheap one that surprisingly does it as well. Autel HT200 about $60 but is getting old so may not be around anymore?
The smaller FOB is worth getting too.
JordanXJL (08-31-2021)
#30
I cannot sadly, as they're located multiple states away from me. But, I do have a multi point inspection scheduled with jaguar and will have them reset it for me then. I'm gonna have them strip the car apart and check it all out thoroughly. After this, I'll tend to issues (if any) and all my preventative maintenance I have on my list.
I own a Lenovo OBD1&2 that I think may do the trick (it works on all other foreigns I've hooked up to. Will be grabbing this from my buddies house this week to run my own scans as well. I have a smaller key FOB on the way now, I dislike the older version and mine is quite corroded anyways. It's also missing the physical small key as well.
#34
As an experienced 2010 XJ owner, I would personally recommend skipping all the maintenance on your 2012, sell it, and buy a 2016 or newer. There are too many parts that were updated from 2012 that make it much more reliable and replacing them all on a 2012 would take lots of time and money (I know because I’ve done it on my 2010). Just my 2 cents.
JordanXJL (09-02-2021)
#35
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
As a new owner of a low mileage 2011 with a long life ahead of it I would be interested in the details.
#36
I’m not in front of my computer right now, but here are some quick things I can remember off the top of my head.
There were a few things that I addressed that are less problematic in a 2016 model:
timing chain tensioners/guides
water pump
various coolant system pipes
sticky interior buttons
Popping/ creaking sun roof
I think also a sunroof rail rust guard was added in later models, but someone else can verify
i also had the original slow infotainment system
i replaced all those except for the sunroof parts
many parts of my car also had wear and tear due to age that would be less prominent in a newer model.
Numerous suspension components/ bushings replaced
engine and tranny mounts replaced
leaking vacuum pump (believe 2016 model uses a longer bolt)
headlight stalk replacement
coolant reservoir tank float issue
rattling wires in doors
supercharger snout replacement
other maintenance included
brake fluid
tranny service
differential service
coolant flush
tpms sensor replacement
brakes and tires
2016 model also has numerous upgrades relative to 2012 including the 8-speed transmission, updated lights, etc.
Anyway I have done lots more work to my car than this, but not everything was essential.
water pump
brake fluid
tranny service
coolant flush
brakes and tires
The following 4 users liked this post by Nedoerr:
#37
#38
Ask yourself - Do I enjoy driving this car? If you do then keep it and do the preventative maintenance. The issues with your car are typical gremlins and can be easily overcome. Tackle the most annoying one first and go from there. I have a 2011 5.0L N/A portfolio and purchased a servicing and diagnostic tool for it which has been invaluable. Any car of this vintage needs a bit of extra TLC and I knew that when I purchased it. It's my daily driver and the best form of preventative maintenance for any vehicle is drive the damn thing 😁
Ken Dreger (09-06-2021)
#39
#40
2012 XJL Portfolio 70 k
Wondering if anyone has this issue or can add some thoughts Thanks in advance !!
. I would love to do this, but lately can't find the time
My vehicle is not blowing cold air at idle. If you get up to highway speeds it will blow cold. Took it to a local mechanic. He mentions they should be serviced at 50k I have 70k. He tried vac and recharge it did not help. Pressures on the low sign were approx 50 but would drop to what he stated was normal range 35-40 when the compressor kicked on, High side was approx 250, He stated the compressor was weak and changing compressor was the answer. I was unable to leave the car at the time. and still trying to find the time to get back. I was told by a friend to try a hose down the condense coil which I did and the AC seems to get cold at idle but did not last long. he said it might be the condenser coil
Mechanic wanted 1200 to change out the compressor
