XJ ( X351 ) 2009 - 2019
2012 XJ leaking coolant
Old 07-08-2017 | 11:37 PM
mycross3's Avatar
Default 2012 XJ leaking coolant
My 2012 XJL was leaking coolant fluid. Dealer replaced outlet pipe and manifold gaskets. Will my CPO warranty cover this? Thanks
Old 07-09-2017 | 12:03 AM
Stuart S's Avatar
Unless your 2012 XJ is still covered as a Certified Pre-Owned Jaguar, you don't have an "extended warranty" from Jaguar - you have a service contract from an unrelated third-party to pay for certain covered repairs. No one on this forum can tell you if you will be covered under that service contract since we don't have a copy of that document. To determine if you're covered, you need to read the fine print in your service contract, in particular the exclusions from coverage.
Old 07-09-2017 | 12:56 AM
mycross3's Avatar
Thanks. I have CPO.
Old 07-09-2017 | 05:24 AM
Stuart S's Avatar
Default Clarifying the Facts
The OP's original post #1 stated: ... "Will my extended warranty cover this." After I replied, he edited his post at 12:58 AM and replaced "extended" with "CPO". See the times that posts ##1 and 2 were edited. I'm pointing this out because otherwise the OP makes me look like I can't read.
Old 07-09-2017 | 11:04 AM
mycross3's Avatar
LMAO!!! I did edit my original post to reduce confusion for the next person who read the thread. I wasn't my intent to make you appear illiterate. Please accept my humble apology.
Old 07-09-2017 | 12:25 PM
DShades's Avatar
My understanding of the CPO is that anything plastic/rubber or a "normal wear" part = Not covered.
I think Topix can pull up a copy of the CPO warranty. I also had one in my glove compartment.
Old 07-09-2017 | 04:01 PM
Stuart S's Avatar
No apology necessary, as you didn't intend any harm or disrespect. Thanks, anyway, for the apology.
Old 07-10-2017 | 10:57 AM
Brutal's Avatar
Its covered, hoses are not
Stuart S (07-11-2017)
