2012 XJL Supercharged Rear Speakers and issue?
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
I just bought a beautiful 2012 XJL supercharged and it is great. My question to any owner is:
For some reason, the rear speakers sound really weak. Even if I change the fader to rear. The dealer told me this was "Normal" but I do not buy it. Can anyone help me with this issue.
I have the Meridian 825 watt 20 speaker system and I think it is outstanding. As for rear speakers, they are there and I can fade back to them but they are not quite as loud as the other speakers. However when the system is on the Meridian Trifield setting all my occupants have clear full range enveloping sound and feel that each one is in the center of the audio. As for base, when the windows are closed i can barely make out the sub woofers and the base is good , but open the windows and I think I am a kid with humongous sub woofers. So I think that Jaguar made a good move to Meridian just as Range Rover and McLaren.
The B&W is an equal opportunities system. All occupants get the full stadium effect.
Also, I haven't noticed any difference in performance between loaded and unloaded. There aren't any speakers in the boot cavity (the subwoofers are in the front doors).
Location: Mooresville, NC (Race City USA), home of most NASCAR teams.
Problem is, today's cars are hermetically sealed much better than years ago, to quiet the interior from extraneous noise, and the passenger compartment is better sealed from the trunk or boot compartment. And, although their are vents in the the rear fender structures of the XJ/XJL that allow easier closing of doors, these vents don't act at low enough pressures, nor quick enough, not to restrict or depress the pressure waves of the cars stereo system base notes, and therefore reduce their perception by our hearing system.
Giles, I beg to differ with you, in that the sub-woofers are indeed located in the rear shelf and have openings into the boot (trunk). I'll attach the Meridian In-car Audio press release for the XJ Ultimate (this is the same system used on all XJs with 825 watt systems from MY2013 on). While the speakers and amplification changed the speaker compliment and locations were carried over from the Bowers & Wilkins 1200 watt audio systems. Also, for those that are looking to replace speakers it shows the sizes.
The lack of bass while can be annoying was known by B&W. Attached is the link from the whole article but I quote the following below.
However, B&W points out that “when you turn up the sub on the interface it does boost sub bass level to the parcel shelf bass speakers which, they admit, are under utilized most of the time because the door bass drivers are so potent. They point out and I concur that “the system goes quite ridiculously loud but more importantly is never stressed”.
First Listen: 2011 Jaguar XJL & The B&W 7.1-channel System | The Absolute Sound
Hi there!
I also had the same issue many owners have with no rear fade and poor sound with the 1200W B&W system.
Thanks to this forum and some persistence I had the amplifier swapped out from a 2015 Model. Don't ask me how as I know the new cars are supposed to be different but anyhow that is what the dealer told me....that they replaced the amplifier. Now my car stereo sounds amazing not only do the subs in the trunk work but the overall sound has improved dramatically.
I now cannot wait to get into my car to hear the audio system.
To all owners......do not accept "this is normal" as an answer from your dealer and others on this forum. If you have no sound when you fade to the back your amp is faulty as many are.....print this post and others like it and take them to your dealer.
Good Luck!
Good Luck!
Centering the sound work like a resyncronization depending on the air volume of the trunk. Just try it incredible!
