XJ ( X351 ) 2009 - 2019
2013 XJ
Old 11-29-2019, 06:36 PM
Robinhill's Avatar
Default 2013 XJ
2013 Jaguar XJ, running rough and burning fuel way too much and
Old 11-30-2019, 07:19 AM
Thermo's Avatar
Received 3,923 Likes on 3,223 Posts
RObin, hopefully you have a check engine light. Get the codes read at a local auto parts place and post the code(s) here. With the info that you have posted, it could be way too many things and trying to have you go through all of them would be very costly. We will help, we just need a little bit more information to help.
Old 11-30-2019, 09:12 AM
Robinhill's Avatar
I haven't found an auto parts store that can read the codes
Old 11-30-2019, 09:14 AM
Robinhill's Avatar
It appears that it is just pushing raw fuel into the exhaust. Not sure if it's a stuck injector or something more severe
Old 11-30-2019, 12:10 PM
Nedoerr's Avatar
If you see white smoke and smell raw fuel it is almost always a stuck injector. But you should definitely buy an OBD scanner, they are the best diagnostic tool money can buy.
Edit: If it is an injector, you can buy the Bosch Landrover ones for about $80 per injector.
Old 11-30-2019, 12:24 PM
Received 2,675 Likes on 1,836 Posts
Diagnose and correct the source of raw fuel entering the exhaust as catalyst damage is the result.
You can use a smart phone with the Torque app and a Bluetooth adapter connected to the vehicle through the OBD port to read various functions including set and pending DTCs.
Old 11-30-2019, 01:19 PM
Thermo's Avatar
RObin, if they are telling you that because you own a jag, that they don't have a reader to read the codes, they are full of it. Tell them to connect their code reader and give us that information. Your Jag does not use anything special for the more simple codes like what are seen for the engine. yes, if you get into the enhanced codes (ie, the 7 digit ones), then yes, they don't have a reader for those. But, all we need are the 5 digit ones (P and 4 numbers) to get you going in the right direction.
ALong the lines of what NBCat is saying, take a look at the following links:
Via E-bay: https://www.ebay.com/itm/ELM327-V2-1...ecb5334fcc23a2
This will work for you, then you just have to download the "Torque" app for your android phone. If you have an Apple phone, you will need to find an amp that reads OBD codes.
Thru Amazon:
Amazon Amazon
Again, download the Torque app and you are golden.
Using it is simple. Under the steering column on the left side, there is an opening that the blue piece will plug into. Leave your foot off of the brake and press the START/STOP button. This will turn on the car but not start the engine. Open up the app and press the gear indicator. From there, you can select "Fault Codes" and then "Show Logged Fault Codes". Tell us what is listed on your phone and we can help you out.
Old 12-02-2019, 04:24 PM
Robinhill's Avatar
Default Engine code
The code reading I got was P0305
Old 12-02-2019, 04:28 PM
Robinhill's Avatar
Could it be the high pressure fuel pump over pressurizing the injectors
Old 12-02-2019, 05:09 PM
Robinhill's Avatar
P0 305
Old 12-03-2019, 05:29 AM
Thermo's Avatar
RobinHill, the code you have is for a misfire on cylinder #5. Could it be the fuel line pressure being too high, sure. But, I also think that you would be seeing this problem on many other cylinders too since all the fuel injectors share a common fuel rail. So, too high of pressure on one fuel injector is seen on all of them. How many miles are on your current set of plugs. Odds are, your problem is either associated with the coil or the plug itself. If you are nearing 100K miles on your car, then I would say to start with a plug change and during the plug change, have the coils visually inspected for any signs of failure. See what you have at that point.
Old 12-03-2019, 05:43 AM
Robinhill's Avatar
I see other codes for some of the other cylinders, at least 3 have the same issue
Old 12-03-2019, 05:45 AM
Robinhill's Avatar
I'll scan it again but I tried to clear it and that was the only one that came up again
Old 12-03-2019, 07:11 AM
Robinhill's Avatar
I just started the car again and the code reader just say's P0305, but the exhaust is billowing white smoke that smells like raw fuel. I have plugs, coils and injectors showing up today. With the excess fuel consumption, could it be more than one stuck injector ?
Robinhill's Avatar
The car has 66k miles
Old 12-03-2019, 07:13 AM
Robinhill's Avatar
How hard is it to get to the spark plugs ?
Old 12-03-2019, 11:01 AM
Thermo's Avatar
RobinHill, from what you are describing, you have a failed open fuel injector. That would cause all the problems that you are seeing, even the misfires on the other cylinders (computer has to "guess" when the reading on the O2 sensor is associated to a specific cylinder. It will sometimes get the timing off a little bit, especially wiht the engine going up and down in RPMs.
Big thing thta I would tell you not to do is to turn the car on and not have the engine running. A fellow member here had a similiar problem and he hydrolocked his engine. It was easy to clear, but he was blowing a 400 amp fuse in his car due to the starter not being able to roll the engine.
Old 12-07-2019, 11:44 AM
Skot Robertson's Avatar
I just went thru this same thing. I was driving home form work and the car started missing. Continued to drive home and gas was literally pouring out of the exhaust.
Had to replace the #5 cylinder fuel injector. I ordered the Bosch replacement part from Rock Auto. After mechanic got thje injector in, discovered 1 of the oxygen sensors also needed replaced. Total bill was ~$1450
Im a little nervous another injector could go bad. Thinking about getting rid of it.
It may have been just a fluke that it went bad too.....
Old 12-07-2019, 11:49 AM
Robinhill's Avatar
That sounds just like mine. I also think its the #5 injector, and maybe the #3 as well.
Old 12-08-2019, 01:53 AM
Robinhill's Avatar
Default miles
How many miles were on your car, I'm at 66K
Quick Reply: 2013 XJ
