2013 XJ 3.0 AWD Supercharger and Cooling System Overhaul
#61
For the coolant, I used a vacuum refill kit with my air compressor. I highly recommend this method to get it filled. Otherwise, I read on here that the dual coolant system for this model sends all coolant bubbles to the reservoir, so it naturally bleeds. I’m not the expert, just a messenger about that. I haven’t had any trouble in case there were a few bubbles introduced when my vacuum fill was nearing its end.
https://a.co/d/7ik7yJX
#62
#63
On any hose or oring connections in the cooling system, I always use Hylomar. It never dries and acts as a lubricant. It makes it much easier to disassemble later. It’s also good for holding gaskets in place during assembly. Amazing stuff for these purposes.
https://a.co/d/dKndILE
#64
#65
My supercharger is stuck on something the two pins in the middle have disconnected but its not lifting up seems like it stuck on something towards the back the front seems very loose
whatever it is I don't want to pull to hard and break w-ever its stuck on or maybe I am not pulling hard enough? I have watched videos on youtube once the two pins disconnected does not take much effort to lift out
Watch video
Watch video
#67
Watch video
https://youtu.be/HI1fWNKo4KU
Watch video
#68
Everything was going nice and smooth until I got to this stuck supercharger
this guy had to get on top of the engine and pull
#69
All six bolts have been removed you may be right the pins are still holding it The front lifts about half inch the back not much play the pins are probably rusted any ideas ? any special tools?
https://www.youtube.com/watch?v=z97PBTyvmZ0
#70
#71
For the O-rings I don’t recall but sounds good to add a bit for sealing. Maybe the guide would mention that.
Where is the Supercharger oil? at the back in the black box? with a T30 screw on top to drain and fill? How did you drain the oil?
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/img_7901_b40871d773dc8ae9f193348dd7312d7b76761239.jpg)
#74
I would recommend some light grease for the o-rings but nothing heavy that would get into the coolant system. Again. I did not use any, maybe a little residual coolant.
#75
The oil is only for lubricating the 2 big gears in back, so it probably doesn't take a lot to be picked up by those gears. The oil does not lubricate any of the bearings and doesn't even make it to any part of the front of the supercharger.
#76
#77
Another problem I cant get the aluminum pipe in Impossible I don't think its the gasket I think its metal on metal Is this normal ? I put a lot of grease still it will not go in
I'm thinking about getting a new plastic pipe from Jaguar and forgetting the aluminum upgrade
i used coolant on my O-rings and pushed straight down. Not sure why yours insnt working 🤔 dimensions seems on point with the oem.
#78
Try to smooth off the second camber on the Alu pipe with a touch of fine wet and dry (with o-ring removed so you don't get bits of Alu on the ring)? I found the 'angles' on my Alu pipes a bit aggressive. Once the pipe is in place the 'shoulder' does nothing.
In the end I wimped out of fitting the Alu pipes on the recommendation of my indie who felt there wasn't enough 'mileage' on them yet to recommend. So went for new-style plastic, knowing I might need to do it again in a few years or so.
#79
The original one I ordered off of Ebay did not fit with or without the o rings
The second one I ordered fit without the o rings but would not fit with the o rings
Finally the 3rd one fit with the o rings although not as snug as the OEM
