2013 XJ 3.0 Supercharged Engine Noises
Got several noises going on with my 2013 XJ. Never owned one of these before so I'm not sure what these sounds are and if they're trouble or not. It has a little over 104,000 miles. No check engine light, codes, or strange warnings.
Exhibit A.
First video is obnoxious rattle that sounds like it is coming from passenger side back of engine but also sounds like it may be coming from middle of supercharger, can't really tell.
Exhibit B.
Second video is just the engine idling after having warmed up for a few minutes. I've had many vehicles that are noisy in cold Michigan winter like this until they've been running for a long time but just don't know if this is how this car should sound.
Exhibit C.
Final video is a sort of clunking/rough sound the car makes when the engine is turned off.
Any and all help is greatly appreciated!
Exhibit A.
Exhibit B.
Exhibit C.
could be your supercharger isolator is gone, that is what the third video certainly sounds like. It can lead to a loud supercharger while running as well.
Get the vehicle checked by a qualified mech, hopefully just the isolator. Doesnt sound like chain slap or anything bottom end, but get it checked asap to make sure.
hayesk11 (01-04-2022)
Received 3,223 Likes
hayesk11 (01-08-2022)
And not just the rear cross-over pipe, get the two front ones (upper and lower) changed out as well and make sure they use the newer updated versions that are one piece instead of the cruddy original two piece ones which are prone to split (same with the rear pipe).
dmchao (01-08-2022)
XJsc-guy
06-14-2015 03:49 PM
FS[SouthWest]: Jaguar 2013 XF 3.0 Supercharged Engine Cover
albert328gts
01-19-2014 11:44 AM
Executive
06-26-2013 10:22 AM
