2013 XJ 3.0L AWD Coolant Up in Smoke
Alas, the inevitable happened to me on the way home last night in my 2013 XJ 3.0L AWD 128k miles, poofing white smoke from the hood, coolant smell and water dump on the shoulder since I immediately stopped and waited for a tow truck. I bought this car with 125k miles and it was inspected Aug 22 by a dealer with two small leaks corrected with new thermostat hoses (C2Z26930 and C2Z29258) between coolant reservoir and throttle housing. I don’t know if or when the water pump was replaced.
Haven’t heard from the shop on compression test yet, but I’m trying to build a good list of best parts for water pump, hoses and fittings. Please tell me if anyone has experience with the aluminum connector tube and crossover tubes and the best supplier?? I really don’t want to see this failure again.
Thanks!
Optional: Supercharger snout replacement with coupler would be nice since I have rattling every time I turn it off. Seems like a good opportunity to get it done, right?
Water Pump:-AJ813909 #1– latest Jaguar design (~2015)
-4x Bolts C2Z1859
Hoses/Pipes:
-AJ813917 plastic – want to upgrade to metal (ebay?) - $63 for both
-AJ813865 plastic – want to upgrade to metal (ebay?)
-Aj813565 rubber
-C2Z28467 plastic
-AJ89664
-C2D6005
Connector Tube
-C2Z18658 – want to upgrade to metal URO product LR028136PRM (Rock Auto)
Gaskets/O-Rings
-2x Oil cooler O-ring seals - AJ811539
-2x Engine coolant pump gasket AJ813609
- O-ring LR018275
Gasket - AJ811948
Gasket - AJ811576
Gasket - AJ811590
_________________________
Supercharger Snout
C2D52713
Supercharger Coupler – rattles
-Coupler Isolator Oil-Filled Nylon
Thanks!
-4x Bolts C2Z1859
Hoses/Pipes:
-Aj813565 rubber
-C2Z28467 plastic
-AJ89664
-C2D6005
Connector Tube
Gaskets/O-Rings
- O-ring LR018275
Gasket - AJ811948
Gasket - AJ811576
Gasket - AJ811590
Supercharger Snout
C2D52713
Received 3,209 Likes
See here for a kit of many of those parts with the alu pipes: https://euro-amp.com/products/jaguar...charged-engine
And here for just the two front pipes in alu going cheap: https://www.ebay.com/itm/224893885947
Got my car back from the shop today! Looks like leak was isolated to the vent hose C2D6362 from the coolant reservoir to the upper coolant pipe AJ813917. Didn’t seem like this shop was keen on replacing the pump and associated hoses since all checked out at this time. I’ll have to dig into the supercharger at some point with the rattling coupler, so I’ll plan to knock it out with a more willing shop!
apparently 10 years is the lifetime of this hose!
One of the two thin tubes at the upper coolant pipe end cracked/split and leaked, and when I took it off and replaced it with a new part it was so brittle it crumbled in my hands and both connectors at that end snapped off completely when I tried to pry them off.
The car was about five years old at the time so I would say 10 years is a good run for this hose and I would class replacing it as a routine maintenance item, especially as it's cheap and easy to replace.
QP7 (08-22-2023)
kstevusa
02-12-2015 05:21 PM
