XJ ( X351 ) 2009 - 2019
2014-15 XJR Exhaust Finishers
Old 12-23-2015, 12:23 PM
Rostman's Avatar
Stuart S (12-23-2015)
Old 12-23-2015, 12:29 PM
Rostman's Avatar
Originally Posted by XJsss
Thank you soo much for all the documentation. To me, the only thing that prevents using the old tail boxes is the hanger needs to be cut off the old pipe and somehow welded to the muffler. But it looks like we can use the new tailboxes and tips. My only question is that it appears that the old center section comes out in a "Y" in front to attach to the catalytic converter pipes and the new center section connects right at the front muffler. Many thanks. It sounds great, but not unlike the stock sound maybe a couple of DBs louder.
As for me you do not need any welding after the hanger would be cut off. You will just mount the XJR finisher and tighten the bracket on the finisher. So you do not need to buy XJR tailboxes.
But after video from GoPro i can here there is some difference. So if you want to make the sound more agressive you must definitelly go for the XJR backboxes.
Old 12-23-2015, 04:26 PM
XJsss's Avatar
Thanks for the great sound clips. Really sounds great. Last question how is the sound inside? Is it louder than the stock exhaust system and if so how much do you think? Looks like you are enjoying warmer weather than usual there in Moscow.
Old 12-24-2015, 02:56 AM
Rostman's Avatar
Inside it's completely the same. You can't here any difference at all.
Usualy in that time we have Moscow completelly covered with a lot of snow but this year is horrible. We are like in Florida now.
Old 01-12-2016, 02:38 PM
Rostman's Avatar
QTP wxhaust cutouts were installed last holidays. Here are some sound check clips.
Old 01-13-2016, 09:17 AM
XJsss's Avatar
Sounds great, but is there a clip where you start off closed and then transition to the open cutout as that would be very interesting to hear. Also, looks like the snow has arrived. Be well!
Old 01-13-2016, 10:00 AM
Stuart S's Avatar
Received 6,318 Likes on 3,464 Posts
Default Music To My Ears!
Rostman,
That's the best sounding XJ I've heard! Awesome!
It's interesting how little things change after 55 years. Your XJ's exhaust sound reminds me of the promo record "Sounds of Corvette" from 1961 that was narrated by Zora Arkus Duntov, the "father of the Corvette". That Corvette was equipped with the optional off-road exhaust that had round straight through mufflers instead of oval baffled mufflers. Listen and enjoy!
By the way, Zora Arkus Duntov lived a very interesting life: https://en.wikipedia.org/wiki/Zora_Arkus-Duntov
Stuart
  #28
Old 04-19-2016, 10:32 AM
Nasser xkr's Avatar
Hi guys is there any difference between the 2014 Xjr exhaust finishers and the 2016 xjr????? What I mean is the tailpipe finisher.
dsnyder586
04-04-2019 02:38 PM
ym37tech
02-08-2016 01:04 PM
mhenz
09-14-2015 07:47 PM
Dickie_L_J_O
09-13-2015 07:44 AM
Quick Reply: 2014-15 XJR Exhaust Finishers
