Hi, I am trying to complete the Strutmasters conversion on my Jaguar and need assistance locating the ah42-14d392-ab Suspension Control Unit. Instructions show the unit in the trunk right side but on my model it is not there. Strutmasters is no help
UPDATE - I have determined that the Suspension Control Module might be behind the rear seat. Issue now is that I have the Premium "Executive" seat package and the seat appears to be very difficult to get forward to access the module. Any advise on getting the seat forward to access the module would be appreciated. I did find instructions on removing the entire seat but it was 37 steps and is vague.
Why are you removing the rear air struts? This model XJ does not have much if any problems with the rear air struts? Almost nothing on the forums about problems?
Now the previous version XJ had a TON of air suspension problems and I have installed a complete Strutmaster kit in an 2006 XJ replacing all 4 air struts with conventional steel coils.
No help on the module location but I will say on the previous generation XJ that module was behind the upper rear seat back and required back seat removal to access the plugs to bypass the module.
Next question is will you have errors or dash light because the car no longer see's the rear air suspension control module?
