2014 XJL Battery Replacement
Rochelle battery is starting to die. Need to replace it. Wondering if it's as simple as replacing the current battery with another compatible GMT battery? Is there any computer work that needs to be done by the dealer? Should I leave it on a trickle charger as I'm replacing it? Anything unusual that needs to be done or can I just swap it out like any other car?
Rodgerrabbit (05-18-2023)
I really don't want to post new but I read through every 351 post that had "battery" in its topic and none of them specifically talked about how to REPLACE the battery. Many talk about what happens why a battery drains, or died and the trunk won't open, etc.... but none specifically talk about the battery replacement procedure. Perhaps you could be so kind and point me at one of the pertinent posts that you think addresses this specifically. Perhaps it's a good topic to make a sticky? Thank you
The following 2 users liked this post by Blepore35:
QP7 (10-06-2023),
The battery module needs to be reset at dealer. After replacing battery.
Reset windows, clock and parking brake. You can use another brand battery as long as correct spec for cca. Interstate is a great brand and many other batteries over the years i have tested dont actually test up to the specs on the battery
thanks brutal. So is there no need to run a trickle charger to maintain current while swapping out the battery? Sounds like i have to spend the money at the dealership to reset things no matter what? Like to do it myself if possible but i understand some things are "dealer only"
The following 2 users liked this post by Brutal:
QP7 (10-06-2023),
The following 2 users liked this post by Mark SF:
QP7 (10-06-2023),
I'll be visiting Interstate Battery near me to have them test the battery & replace it if the confirm the occasional "low battery" and a new one is needed.
They're familiar with the drill on vehicles that are sensitive to the battery being disconnected.
As long as the salesman is experienced & familiar, they put a 12VDC source in line while they're replacing the battery, and the car never knows that the battery was replaced.
The only reason the vehicle needs to have the "new battery" reset is because it lost power.
Another alternative is subscribing to or buying SDD to reset it yourself.
The following 2 users liked this post by 12jagmark:
QP7 (10-06-2023),
they're familiar with the drill on vehicles that are sensitive to the battery being disconnected.
As long as the salesman is experienced & familiar, they put a 12vdc source in line while they're replacing the battery, and the car never knows that the battery was replaced.
The following 3 users liked this post by Brutal:
Well then, I stand corrected. I don't recall where I'd gotten the bad guff from, but sorry to pass it on.
What happens if the battery shop does use a battery surrogate while they replace the battery?
Regardless, that's the sort of thing I have the SDD for.
Thanks Brutal.
Thanks Brutal.
The following 2 users liked this post by Nightshadow:
Ken Dreger (01-30-2024),
What I have been able to find out is with all the problems Jaguar had with the XJ and batteries that in 2013 or 2014 they upgraded the BMS.
What this does is measure the amps coming out of and going back into the battery. Then it models the condition of the battery and will set dash board messages about what it (the BMS) thinks is going on with the battery.
So if you install a new battery you have now lost all the prior history because that battery is gone and has been replaced. Now in theory the BMS will be incorrect. The dealer can use the SDD tool to tell the car it has a new battery and to start the BMS over. I have also read that Jaguar realized not every owner would know to reset the BMS when changing the battery out. In the shop manual there is mention that the BMS will self calibrate (what ever that means!) every so often even if it's not been reset. This is to try and keep the BMS correct and up to date on the batteries condition.
This is also why you should NOT hook the negative battery terminal to your jumper cables. Attach the negative lead to the base metal of the car. This way all the current will go thru the BMS and be counted.
Note the blue and white wires attached to the negative battery post in the picture below. This is the BMS (Battery Monitoring System)
Also note the nice corrosion I have on my small battery negative post. Oh well something else to clean up!
The following 4 users liked this post by clubairth1:
No computer dealer software reset required when changing battery
Scheduled an appointment after changing out my original battery for an interstate. Expensive but worth it in the long run. Made an appointment with local dealer to have them update the voltage regulation through the software. Got there and the service advisor let me know that there's no need for the software update.. at least on my 2014. I didn't ask about earlier years. The automatic up and down windows, the clock, and the parking brake can't all be reset easily yourself. So don't waste the time and money and having a dealer change out your battery. There is no need. Also no need to maintain voltage when you swap it out.
The following 3 users liked this post by Blepore35:
Clubairth1. The wires are not the bms. They go into the bms which is the black box on the negative terminal they go into. Also while the bms self calibrates this is not a reset of monitor info and when replacing a new battery be it the main or the aux you have to reset adaptations just like trans and ecu have adaptations. If jaguar did not still or require this to be done they would not pay us for sdd use to reset this info when replacing a battery under warranty. They would not pay and state "not required."
Nightshadow (08-06-2019),
