2014 Xjluxury rear driver door not looking
Hello everyone I have a question, unfortunately I had an accident which I had to replace the rear driver door skin only!
The window glass & motor, shade and the lock were working before replacing the door shell
after the door is replaced my window, privacy shade and door lock stopped working but when I press the lock button it looks all other doors so there is electric power there!
But when I look the car from out side it doesn’t lock that specific door or fold the mirror in or flash the turn signal then after 5-10 seconds it beeb once.
Can anyone help?
Can anyone help?
mikebaker3 (09-15-2021)
I too cannot electrically unlock the LR door. Like your situation, it will lock, but must be manually unlocked with the inside handle.
While I was having my sunroof rattle fixed, I mentioned this to the (highly experienced Jaguar) mechanic. I thought it would be a minor repair; maybe a defective solenoid. Nope, it requires replacing a module costing several hundred dollars. I suspect you will ultimately face this same solution. Like Stuart says, return to the repair shop.
