2014 XJR SEEMS LIKE KNOCK but its not
From experience can be either or both. Supercharger coupler and or timing chain tensioners and guides. If the knock seems to be coming from the top of the engine it's probably the coupler.
Old style Guide worn mating surface
New style guide has hardend mating surface
new tensioner
new tensioner
mikebaker3 (09-27-2019)
I can hear the SC coupling knock just a bit at shutdown on my 2014 XJR. 40K miles.
In fact I never even noticed it until I read the description on this forum. Just thought it was a normal noise!
Can you describe exactly when you hear it? Starting, stopping, at idle?
Coupler is VERY common. Timing stuff not so much. I recently picked up the complete snout with bearings but some people just replace the spring loaded coupler. However we have had people post pictures of the spring coupler eating into the metal shaft so I decided to change the entire front snout when the time comes. Paid about $200 including shipping from the UK.
Can you post the last 6 digits of your VIN?
From my research the XJ had the last timing equipment change at VIN V58603. We "think" this is the latest and greatest version done sometime in 2014.
My 2014 XJR is around V54000.
Also if you are worried try to post a video of your noise. I am sure someone on here can tell you for sure what it is.
But have you changed the water pump? This has been a trouble spot and I had mine changed at 33K miles by the dealer.
Jaguar changed the recommended motor oil viscosity (! think it was in 2016) from 5W-20 to 0W-20 to minimize hydraulic chain tensioner wear at the first startup of the day. The thicker 5W took too long to build hydraulic pressure and caused noise and wear. Thinner 0W flows faster when cold. The viscosity is the same when hot - 20W.
You should use only motor oil that meets the latest JLR specs. Read this entire thread:
https://www.jaguarforums.com/forum/x...-techs-159928
And this:
https://www.jaguarforums.com/forum/x...il-car-214892/
And this:
Well it's been my experience that Jaguar dealers really don't have a clue what they are suppose to put in!
I fought with Jaguar corporate all the way to the UK before I finally got the correct rated oil put in.
I even sent them all the Jaguar requirements which are outlined in your owners manual. Still got the wrong oil!
From now on I will go back to changing the oil myself at my interval not this screwed up mess of 15K-16K miles!
is it low on the driver's side behind the wheel well area? possibly one of the two mechanical fuel pumps on the engine. lot's of 5.0 s/c engines do the same on warm restarts
xjrmageddon
10-11-2018 05:06 PM
