2015 Jaguar XJL Faulty Eco start/stop function.
Hello …
I am new here and but have been lurking for a year and a bit. I have a 2015 Jaguar XJL and I love the car. Over the past few months the ECO function has been faulty with the car. When I come to a complete stop the ECO function activates shutting the engine down but in the same instance it will start up again. This occurs at every complete stop. I do not have any of the load demanding equipment on like the AC or other load hungry options. So the load on the battery is minimal.
I know there has been a few threads written on this issue that I have read but I have not really noticed any clear diagnosis of the ECO fault.
I took my car to a Jaguar specialist here in Ottawa Canada ( not dealer) and they had mentioned that there is a black junction box located near the small battery in the boot (trunk) that has a series of relays in it that it has a hand in controlling the ECO function. They are suggesting that this junction box is faulty and needs replacement. This black junction box costs about $500.00 + the labour to install it....
Just wondering from other forum members who have experienced this problem if they have had this as a solution to the problem or not.
Thanks in advance,
R27
Thanks in advance,
R27
I had the same problem and code revealed it was the power module. My nav/audio system would reset during the event as well. I just removed the negative cable from the small battery and never looked back. You will get a small amber ECO indicator on the display indicating the ECO mod is disabled but everything else works and the annoying start/stop is gone!
Mark...thanks for this. I was actually reading in the F-type forum and they have a similiar power set up. I have always put a tender on the large battery and assumed by the common connection that the small battery would charge as well. I have read that one guy has found a solution to put the tender on the small battery over night and the ECO fault seems to correct itself. I have placed my tender on the small battery and will report back if this corrects the problem.
That being said I believe the large battery has been there since day one however, I have paperwork that the small battery was changed when I purchased the car in 2017.
This actually bring up another question ...do you always go with dealer supplied batteries or do you replace with a decent alternative grade at a cheaper cost ?
Thanks in advance...
I have read from other posters that you really need to have an AGM battery if you don’t.
I also ran across this TSP but it sounds like something you have to do with the dealer because it requires their diagnostic software system.
https://static.nhtsa.gov/odi/tsbs/20...96426-1020.pdf
clueless123
06-23-2021 02:02 AM
byrnew
05-18-2018 07:16 PM
Macedon
05-18-2014 10:09 PM
