2015 xj sport pedal install problem
purchased c2d8415 sport pedals and had no problem with brake pedal as holes are drilled and old rubber pedal can be pulled off. The accelerator is a problem as it is one piece and plastic with no holes. No instructions.
The new stainless/rubber pedal will fit over the existing pedal but one hole as a minimum needs to be drilled. I am concerned that drilling in this will compromise it's strength.
Dave Grainger (08-24-2016)
